buser
December 10, 2021, 2:30pm
1
Hi,
I have downloaded and created an Live USB as recommended on QubesOS website.
When I start my Librem 15v4 with PureBoots, choose “USB boot” and select “Test_this_media_&_install” from the menu nothing happens after “Starting the new kernel”.
I am not sure what is wrong.
Any suggestions will be very helpful.
Kind regards,
Live USB is not supported. I guess you mean a normal installation USB.
Did you verify the iso?
buser
December 11, 2021, 9:46am
3
Thx. I copied the ISO of the latest, stable release on an external USB drive. I verified the ISO.
flopsy
December 11, 2021, 9:49am
4
@buser
How did you verify the iso?
buser
December 11, 2021, 2:00pm
5
Thx. My steps to verify the iso in short:
fetched Qubes MK with gpg
checked fingerprint
fetched Qubes SK with gpg
verified that the RSK is indeed signed by QMSK
verified that the iso matches the hash value
verified that the hash value is authentic
what version of Qubes? What version of Pureboot on your L15v4?
If running Pureboot Release-19, as documented in the release notes, you need to use Qubes 4.1-RC (or later); the stable 4.0.4 release will not boot.
buser
December 13, 2021, 12:26pm
7
Thx very much. That sovled my issue! Best regards,
