Testing a audio DAC
Full source code in minidisc.
Still not full testing as it needed a 600-400 dollar RCA cable for full featuring…
Just tested on Power9 machine and Gnu System and worked very good, the sound is crisp like a concert super-supa detailed.
I highly doubt that claim.
It is, a good d.a.c it need a good rca cable too at least. Later it needed too a good AMP, plus good cables and speaker.
A super supa RCA cable will transmit the signal with less resistance and loss. This can translate into more detailed and accurate sound.
Explain your current and future audio chain in detail and I will find you a more cost-efficient solution.
I will explain with detail when i get time.
Also looks like Henry Audio is may change the Dac from AKM to TI-PCM.
Also i still not tested the Henry Audio DA-256(AKM) on Librem 5. = (
