There's a need for xdg-desktop-portal-gnome in the repositories
xdg-desktop-portal-gnome is currently not present in the PureOS repositories specifically, so it should be brought over from upstream Debian, as even some Flatpak applications do depend on it and expect it on the system. Such as Flare, the open Signal-protocol messenger. And I am sure there are others, so it would be handy to have available.
It’s not in Debian bullseye either. It was only introduced in bookworm, which means it will be there in PureOS crimson.
Any guess on when crimson will be released?
oh is this why Fluffychat doesn’t work, I’ve error
 ** (fluffychat:2): CRITICAL **: 10:08:36.199: Failed to read XDG desktop portal settings: GDBus.Error:org.freedesktop.portal.Error.NotFound: Requested setting not found
** (fluffychat:2): CRITICAL **: 10:08:36.214: Failed to read XDG desktop portal settings: GDBus.Error:org.freedesktop.portal.Error.NotFound: Requested setting not found
[ERROR:flutter/runtime/dart_vm_initializer.cc(41)] Unhandled Exception: MissingPluginException(No implementation found for method SystemTheme.accentColor on channel system_theme)
#0      MethodChannel._invokeMethod (package:flutter/src/services/platform_channel.dart:294)
<asynchronous suspension>
#1      SystemAccentColor.load (package:system_theme/system_theme.dart:86)
No provider of glFenceSync found.  Requires one of:
    Desktop OpenGL 3.2
    GL_ARB_sync
    OpenGL ES 3.0
    GL_APPLE_sync
It used to work few versions back though.
