As I’ve become more conscious of privacy vulnerabilities and how companies profit from them, I have become increasingly concerned about DNS.
It seems that DNS is (intentionally?) left out of many privacy “solutions”. For example, I used calyxVPN on Android for months before I realized that Android did not send DNS requests through the VPN connection by default, so the network operator was still able to view all the sites that I visited via the VPN, even though I thought that my web traffic was private at the time. What a privacy disaster.
Then, more recently, I was using a firefox-based browser with DNS-over-HTTPS and a “custom” DNS provider entered in the settings. I was traveling and using a public network, and I got an error message that I could not access a site that I was trying to visit, because my browser could not reach Mozilla’s DNS server! Mozilla’s server was not the DNS server that I had entered in the settings! So either (1) Firefox was ignoring my selection to (maliciously?) continue sending all my DNS queries to themselves so they could continue to track all of the sites that I visit, or (2) the error message was incorrect. Either way, it does not instill confidence.
Has anyone else noticed DNS as a highly concerning and little-talked-about privacy problem?
I’m interested to hear your own stories, solutions, frustrations, etc. I really have heard very few people talk about DNS privacy solutions, other than DNS-over-HTTPS generally, which does nothing to protect privacy if, for example, Google/Mozilla is selected as DNS provider.
There are usability issues here to balance. Robust DNS is an availability issue, which may contribute to how things are. It would be nice to have it more secure and private by default, since it is possible. But there is also increased likelyhood that then some things/sites/services may not always work (IMO, that’s normal and gets fixed over time, but some may take a different view and see it as a fail, not as a preventative save).
One of the many mini-projects I will be dealing with in the near future is deploying a Tor exit relay, which also recommends a local caching DNSSEC-validating recursive DNS resolver:
My current thinking is to use Technitium DNS Server since it has a Docker image and a web console:
Afterwards, I plan on providing public DNS resolution, although I am still not sure if I want to support OpenNIC and related TLDs as well.
For home use, it may make sense to block DNS in the firewall except as used by the local DNS server - hence forcing every client device and all applications either to use the local DNS server or to tunnel DNS in some way (whether via VPN - probably good - or via DoH - may or may not be good depending on who the server is). However that does nothing for portable devices when they are being used outside the home. (You don’t make clear whether the “firefox-based browser” was on a laptop or on something else.)
Post 8 in first linked post above covers my direction for home use.
I used […] Android […] What a privacy disaster.
Fixed that for you.
I get that a VPN on Android protects you against an untrusted mobile service provider but it is fairly difficult to make any claim on privacy when you use Android regardless.
That is, even if your DNS arrangements were working as configured, if you are handing your DNS requests over to Android to perform the lookups correctly as configured, you get no guarantees as to the surveillance that Android itself undertakes regarding your lookups.
This is tricky because, in a sandboxed application environment, the operating system may legitimately want to prevent applications doing their own lookups and hence to force the application to hand the lookup to the operating system to perform .. but if you can’t trust the operating system then this too is problematic.
Haha yes, great point, and I agree with you. Perhaps the same can be said for browsers in general these days, or at least those in the firefox and chromium families.
firefox and chromium-based browsers are basically virtual machines with millions of lines of code (and thus practically extremely difficult to audit), the development of which are mostly funded by Google. So why should I expect anything I do in any browser to be private? I probably shouldn’t. Browsers these days are essentially in the same category as Android in that way: a privacy disaster.
Yet, I think I will have to keep using browsers. So it’s interesting to think about how I can limit the harmful impacts whenever I do have to use them.
The way Tor Browser handles DNS sounds promising. Ironically, of course, I believe Tor Browser does not run on the Librem 5, because arm64 architecture is not supported?
Perhaps revealingly, Tor Browser does support arm64, but only for Apple products GNU/Linux has been popular on 64-bit ARM for 10 years (Raspberry Pi), so I find the fact that Tor Browser only runs on Apple arm64 highly fishy. When things like this come up, I definitely get honeypot vibes lol.
I will be aiming to complete the Tor exit relay mini-project by the end of May, so afterwards I will make a topic in the Guides & Tutorials category about how to configure systemd-resolved for DNSSEC and DNS-over-TLS using my DNS public resolver.
Tor Browser for L5 and other arms can be found from the unofficial Tor Browser Ports download | SourceForge.net (see here for more on that) and doesn’t the Carburator app also do the trick (works after a bit of setting up - the first launch didn’t work for me for some reason, so I suggest doing a check on what IP is seen)
Wow, hadn’t noticed that the year hadn’t changed. I find it unfortunate that this hasn’t been made official over time. Even more, it’s baffling that the flatpak is only x86_64.
I have Technitium DNS Server successfully deployed using Docker, but I will need some more time to optimally configure it first before I can deploy the Tor exit relay and reconfigure the systemd-resolved daemon with it.
I got curious if there is any development with this, and discovered that there are already official nightly builds of TORbrowser and Mulvad for linux aarch/arm64 available .debs by TOR Project - even if they are not made available at the download pages (yet?): Index of /nightly-builds/tor-browser-builds
Nightly builds should only be used for development and testing, not production purposes. It is also not clear if either Mullvad Browser or Tor Browser are adapted for the Librem 5’s viewport.
