sudo dmesg (abridged to the last part of the output, capturing the moment of insertion of the USB drive):
[ 23.925612] systemd[1]: Starting systemd-journald.service - Journal Service...
[ 23.932315] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[ 23.938085] fuse: init (API version 7.45)
[ 23.944078] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[ 23.951815] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[ 23.965043] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[ 23.966118] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[ 23.966971] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[ 23.967858] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[ 23.969165] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
[ 23.970794] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[ 23.972529] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 23.973199] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[ 23.974518] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[ 23.975156] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
[ 23.976351] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 23.977066] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[ 23.978348] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[ 23.978914] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[ 23.979950] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 23.980498] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[ 23.981749] systemd[1]: modprobe@loop.service: Deactivated successfully.
[ 23.982381] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
[ 24.004766] EXT4-fs (dm-0): re-mounted 48dd485f-d0a4-485d-883e-6976497c6845.
[ 24.005050] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[ 24.010199] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[ 24.010598] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
[ 24.014383] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[ 24.015976] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
[ 24.018893] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[ 24.019974] systemd[1]: systemd-firstboot.service - First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[ 24.020145] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[ 24.025566] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
[ 24.030028] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
[ 24.034236] systemd[1]: Starting systemd-sysusers.service - Create System Users...
[ 24.036995] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[ 24.084658] systemd[1]: Finished systemd-random-seed.service - Load/Save Random Seed.
[ 24.085800] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[ 24.097200] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
[ 24.111225] systemd[1]: Finished systemd-sysusers.service - Create System Users.
[ 24.135125] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
[ 24.136509] systemd[1]: Finished lvm2-monitor.service - Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 24.166271] systemd[1]: Started systemd-journald.service - Journal Service.
[ 24.199024] systemd-journald[491]: Received client request to flush runtime journal.
[ 24.202294] systemd-journald[491]: File /var/log/journal/e87e2e436c554d8fa42839389570bd04/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 24.652574] zram0: detected capacity change from 0 to 12111872
[ 25.026015] Adding 6055932k swap on /dev/zram0. Priority:100 extents:1 across:6055932k SSDsc
[ 25.069444] mousedev: PS/2 mouse device common for all mice
[ 25.135485] ext2 filesystem being mounted at /boot supports timestamps until 2038-01-19 (0x7fffffff)
[ 25.350482] audit: type=1400 audit(1777319339.393:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=587 comm="apparmor_parser"
[ 25.353657] audit: type=1400 audit(1777319339.396:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=588 comm="apparmor_parser"
[ 25.355176] audit: type=1400 audit(1777319339.400:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=588 comm="apparmor_parser"
[ 25.361375] remoteproc remoteproc0: imx-rproc is available
[ 25.429160] audit: type=1400 audit(1777319339.473:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/libexec/geoclue" pid=596 comm="apparmor_parser"
[ 25.433671] audit: type=1400 audit(1777319339.476:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=595 comm="apparmor_parser"
[ 25.433719] audit: type=1400 audit(1777319339.476:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=595 comm="apparmor_parser"
[ 25.433732] audit: type=1400 audit(1777319339.476:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=595 comm="apparmor_parser"
[ 25.460125] audit: type=1400 audit(1777319339.503:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=589 comm="apparmor_parser"
[ 25.460155] audit: type=1400 audit(1777319339.503:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=589 comm="apparmor_parser"
[ 25.460167] audit: type=1400 audit(1777319339.503:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=589 comm="apparmor_parser"
[ 25.516537] rfkill-hks rfkill-hks: using DT '/rfkill-hks/mic-hks' for '(default)' GPIO lookup
[ 25.516587] of_get_named_gpiod_flags: parsed 'gpios' property of node '/rfkill-hks/mic-hks[0]' - status (0)
[ 25.516623] gpio gpiochip3: Persistence not supported for GPIO 1
[ 25.516637] rfkill-hks rfkill-hks: using DT '/rfkill-hks/mic-hks' for 'soft' GPIO lookup
[ 25.516651] of_get_named_gpiod_flags: can't parse 'soft-gpios' property of node '/rfkill-hks/mic-hks[0]'
[ 25.516664] of_get_named_gpiod_flags: can't parse 'soft-gpio' property of node '/rfkill-hks/mic-hks[0]'
[ 25.516675] rfkill-hks rfkill-hks: No GPIO consumer soft found
[ 25.520979] rfkill-hks rfkill-hks: using DT '/rfkill-hks/camera-hks' for '(default)' GPIO lookup
[ 25.521036] of_get_named_gpiod_flags: parsed 'gpios' property of node '/rfkill-hks/camera-hks[0]' - status (0)
[ 25.521053] gpio-609 (mic-hks): gpiod_request: status -16
[ 25.521062] rfkill-hks rfkill-hks: nonexclusive access to GPIO for (default)
[ 25.521075] rfkill-hks rfkill-hks: using DT '/rfkill-hks/camera-hks' for 'soft' GPIO lookup
[ 25.521088] of_get_named_gpiod_flags: can't parse 'soft-gpios' property of node '/rfkill-hks/camera-hks[0]'
[ 25.521102] of_get_named_gpiod_flags: can't parse 'soft-gpio' property of node '/rfkill-hks/camera-hks[0]'
[ 25.521113] rfkill-hks rfkill-hks: No GPIO consumer soft found
[ 25.586035] rfkill-hks rfkill-hks: using DT '/rfkill-hks/wlan-hks' for '(default)' GPIO lookup
[ 25.586095] of_get_named_gpiod_flags: parsed 'gpios' property of node '/rfkill-hks/wlan-hks[0]' - status (0)
[ 25.586129] gpio gpiochip3: Persistence not supported for GPIO 10
[ 25.586146] rfkill-hks rfkill-hks: using DT '/rfkill-hks/wlan-hks' for 'soft' GPIO lookup
[ 25.586166] of_get_named_gpiod_flags: parsed 'soft-gpios' property of node '/rfkill-hks/wlan-hks[0]' - status (0)
[ 25.586185] gpio gpiochip2: Persistence not supported for GPIO 10
[ 25.597729] rfkill-hks rfkill-hks: using DT '/rfkill-hks/wwan-hks' for '(default)' GPIO lookup
[ 25.597790] of_get_named_gpiod_flags: parsed 'gpios' property of node '/rfkill-hks/wwan-hks[0]' - status (0)
[ 25.597826] gpio gpiochip3: Persistence not supported for GPIO 0
[ 25.597842] rfkill-hks rfkill-hks: using DT '/rfkill-hks/wwan-hks' for 'soft' GPIO lookup
[ 25.597862] of_get_named_gpiod_flags: parsed 'soft-gpios' property of node '/rfkill-hks/wwan-hks[0]' - status (0)
[ 25.597880] gpio gpiochip2: Persistence not supported for GPIO 18
[ 25.676368] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 25.700361] Problem loading in-kernel X.509 certificate (-22)
[ 25.706550] Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[ 25.707957] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 25.709317] Problem loading in-kernel X.509 certificate (-22)
[ 25.751392] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 25.858420] mmc1: new high speed SDIO card at address fffd
[ 26.028200] mc: Linux media interface: v0.10
[ 26.053607] gnss: GNSS driver registered with major 238
[ 26.075078] wm8962 2-001a: customer id 0 revision D
[ 26.156871] videodev: Linux video capture interface: v2.00
[ 26.211446] dw9714 3-000c: using DT '/soc@0/bus@30800000/i2c@30a50000/vcm@c' for 'powerdown' GPIO lookup
[ 26.211486] of_get_named_gpiod_flags: can't parse 'powerdown-gpios' property of node '/soc@0/bus@30800000/i2c@30a50000/vcm@c[0]'
[ 26.211506] of_get_named_gpiod_flags: can't parse 'powerdown-gpio' property of node '/soc@0/bus@30800000/i2c@30a50000/vcm@c[0]'
[ 26.211520] dw9714 3-000c: using lookup tables for GPIO lookup
[ 26.211528] dw9714 3-000c: No GPIO consumer powerdown found
[ 26.219421] s5k3l6xx 3-002d: using DT '/soc@0/bus@30800000/i2c@30a50000/camera@2d' for 'rstn' GPIO lookup
[ 26.219474] of_get_named_gpiod_flags: parsed 'rstn-gpios' property of node '/soc@0/bus@30800000/i2c@30a50000/camera@2d[0]' - status (0)
[ 26.219504] gpio gpiochip0: Persistence not supported for GPIO 26
[ 26.219532] s5k3l6xx 3-002d: probe i2c ffff0000027e6000
[ 26.255765] lm3560-led 1-0053: using DT '/soc@0/bus@30800000/i2c@30a30000/flash@53' for 'enable' GPIO lookup
[ 26.255818] of_get_named_gpiod_flags: parsed 'enable-gpios' property of node '/soc@0/bus@30800000/i2c@30a30000/flash@53[0]' - status (0)
[ 26.255848] gpio gpiochip0: Persistence not supported for GPIO 23
[ 26.265671] s5k3l6xx 3-002d: model low: 0x30
[ 26.266745] s5k3l6xx 3-002d: model high: 0xC6
[ 26.269223] s5k3l6xx 3-002d: revision number: 0xB0
[ 26.276116] hi846 2-0020: using DT '/soc@0/bus@30800000/i2c@30a40000/camera@20' for 'reset' GPIO lookup
[ 26.276168] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/soc@0/bus@30800000/i2c@30a40000/camera@20[0]' - status (0)
[ 26.276198] gpio gpiochip0: Persistence not supported for GPIO 25
[ 26.276213] hi846 2-0020: using DT '/soc@0/bus@30800000/i2c@30a40000/camera@20' for 'shutdown' GPIO lookup
[ 26.276240] of_get_named_gpiod_flags: parsed 'shutdown-gpios' property of node '/soc@0/bus@30800000/i2c@30a40000/camera@20[0]' - status (0)
[ 26.276261] gpio gpiochip4: Persistence not supported for GPIO 4
[ 26.282898] hi846 2-0020: chip id 08 46 using 2 mipi lanes
[ 26.411355] hantro-vpu 38300000.video-codec: registered nxp,imx8mq-vpu-g1-dec as /dev/video0
[ 26.414834] imx7-csi 30a90000.csi: Registered csi capture as /dev/video1
[ 26.430027] debugfs: 'Capture' already exists in 'dapm'
[ 26.509304] input: imx-audio-hdmi HDMI Jack as /devices/platform/sound-hdmi/sound/card0/input5
[ 26.522931] asoc-simple-card sound: using DT '/sound' for 'simple-audio-card,hp-det' GPIO lookup
[ 26.522985] of_get_named_gpiod_flags: parsed 'simple-audio-card,hp-det-gpios' property of node '/sound[0]' - status (0)
[ 26.523017] gpio gpiochip2: Persistence not supported for GPIO 9
[ 26.523114] asoc-simple-card sound: using DT '/sound' for 'simple-audio-card,mic-det' GPIO lookup
[ 26.523128] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpios' property of node '/sound[0]'
[ 26.523142] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]'
[ 26.523153] asoc-simple-card sound: using lookup tables for GPIO lookup
[ 26.523160] asoc-simple-card sound: No GPIO consumer simple-audio-card,mic-det found
[ 26.538306] input: WM8962 Beep Generator as /devices/platform/soc@0/30800000.bus/30a40000.i2c/i2c-2/2-001a/input/input8
[ 26.539106] hantro-vpu 38310000.video-codec: registered nxp,imx8mq-vpu-g2-dec as /dev/video2
[ 26.542456] gpiochip_find_base_unlocked: found new base at 672
[ 26.555871] imx7-csi 30b80000.csi: Registered csi capture as /dev/video3
[ 26.567501] gpio gpiochip5: (wm8962): added GPIO chardev (254:5)
[ 26.567530] gpio gpiochip5: registered GPIOs 672 to 677 on wm8962
[ 26.641329] input: Librem 5 Headphones as /devices/platform/sound/sound/card1/input6
[ 26.641562] input: Librem 5 Headset Mic as /devices/platform/sound/sound/card1/input7
[ 26.700085] asoc-simple-card sound-wwan: using DT '/sound-wwan' for 'simple-audio-card,hp-det' GPIO lookup
[ 26.700121] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpios' property of node '/sound-wwan[0]'
[ 26.700137] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound-wwan[0]'
[ 26.700148] asoc-simple-card sound-wwan: using lookup tables for GPIO lookup
[ 26.700156] asoc-simple-card sound-wwan: No GPIO consumer simple-audio-card,hp-det found
[ 26.700164] asoc-simple-card sound-wwan: using DT '/sound-wwan' for 'simple-audio-card,mic-det' GPIO lookup
[ 26.700176] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpios' property of node '/sound-wwan[0]'
[ 26.700189] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound-wwan[0]'
[ 26.700199] asoc-simple-card sound-wwan: using lookup tables for GPIO lookup
[ 26.700205] asoc-simple-card sound-wwan: No GPIO consumer simple-audio-card,mic-det found
[ 27.715600] Bluetooth: Core ver 2.22
[ 27.715761] NET: Registered PF_BLUETOOTH protocol family
[ 27.715768] Bluetooth: HCI device and connection manager initialized
[ 27.715788] Bluetooth: HCI socket layer initialized
[ 27.715797] Bluetooth: L2CAP socket layer initialized
[ 27.715815] Bluetooth: SCO socket layer initialized
[ 27.751037] configfs-gadget.g1 gadget.0: HOST MAC 5e:94:66:c4:f6:90
[ 27.751064] configfs-gadget.g1 gadget.0: MAC 4a:04:94:98:05:04
[ 27.841825] st-magn-i2c 1-001e: DRDY on pin INT1 specified, but sensor does not support interrupts
[ 27.845493] st-magn-i2c 1-001e: interrupts active high level
[ 27.920809] redpine_91x: rsi_probe: ***** 9116 Module *****
[ 27.920954] redpine_91x: redpine_hal_device_init: oper_mode = 5, coex_mode = 2
[ 27.922157] redpine_91x: Received Board Version Number: 10
[ 27.923262] redpine_91x: rsi_load_firmware: Loading file RS9116_NLINK_WLAN_BT_IMAGE.rps
[ 27.923416] RSI-SDIO WLAN mmc1:fffd:1: Direct firmware load for RS9116_NLINK_WLAN_BT_IMAGE.rps failed with error -2
[ 27.923431] redpine_91x: rsi_load_firmware: Failed to open file RS9116_NLINK_WLAN_BT_IMAGE.rps
[ 27.926891] redpine_91x: ***** Loaded Firmware *****
[ 30.799927] hdmi-audio-codec hdmi-audio-codec.1: HDMI: Unknown ELD version 0
[ 31.487268] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 31.487330] Bluetooth: BNEP socket layer initialized
[ 31.830356] [drm] Connector status: 0
[ 32.620678] usb 1-1.2: new high-speed USB device number 4 using xhci-hcd
[ 32.715577] usb 1-1.2: New USB device found, idVendor=2020, idProduct=2060, bcdDevice= 0.00
[ 32.715638] usb 1-1.2: New USB device strings: Mfr=3, Product=2, SerialNumber=4
[ 32.715646] usb 1-1.2: Product: Qualcomm CDMA Technologies MSM
[ 32.715652] usb 1-1.2: Manufacturer: Qualcomm, Incorporated
[ 32.716115] usb 1-1.2: Device is not authorized for usage
[ 32.843094] usb 1-1.2: authorized to connect
[ 32.991187] usbcore: registered new interface driver usbserial_generic
[ 32.991254] usbserial: USB Serial support registered for generic
[ 33.012271] usbcore: registered new interface driver cdc_wdm
[ 33.025628] usbcore: registered new interface driver option
[ 33.027581] usbserial: USB Serial support registered for GSM modem (1-port)
[ 33.063200] qmi_wwan 1-1.2:1.4: cdc-wdm0: USB WDM device
[ 33.065471] qmi_wwan 1-1.2:1.4 wwan0: register 'qmi_wwan' at usb-xhci-hcd.4.auto-1.2, WWAN/QMI device, 02:46:40:44:6d:86
[ 33.066836] usbcore: registered new interface driver qmi_wwan
[ 33.067628] option 1-1.2:1.0: GSM modem (1-port) converter detected
[ 33.068225] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
[ 33.071036] option 1-1.2:1.1: GSM modem (1-port) converter detected
[ 33.072890] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
[ 33.073782] option 1-1.2:1.2: GSM modem (1-port) converter detected
[ 33.074438] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
[ 33.074736] option 1-1.2:1.3: GSM modem (1-port) converter detected
[ 33.075084] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB3
[ 33.120978] redpine_91x: ================================================
[ 33.121003] redpine_91x: ================ RSI Version Info ==============
[ 33.121008] redpine_91x: ================================================
[ 33.121012] redpine_91x: FW Version : 0.2.0.16
[ 33.121019] redpine_91x: RSI FW Version : 1610.0.2.0.0024
[ 33.121025] redpine_91x: Driver Version : RS9116.NB0.NL.GNU.LNX.OSD.2.0.0.0024
[ 33.121031] redpine_91x: Operating mode : 5 [Wi-Fi STA + BT EDR]
[ 33.121036] redpine_91x: Firmware file : RS9116_NLINK_WLAN_BT_IMAGE.rps
[ 33.121041] redpine_91x: ================================================
[ 33.127511] redpine_91x: rsi_send_bt_reg_params: Sending BT reg frame
[ 33.127538] BT REG PARAMS: (length = 21)
[ 33.127543] 05 60 00 00 00 00 00 00 00 00 00 00 00 00 55 00
[ 33.127594] 00 00 01 1e 02
[ 33.127961] redpine_91x: HCI module init done...
[ 33.128241] redpine_91x: RSI HCI DEVICE "hci0" open
[ 33.251959] redpine_91x: RSI `hci0' flush
[ 33.251989] redpine_91x: RSI HCI DEVICE "hci0" closed
[ 33.251994] redpine_91x: rsi_hci_close: device `hci0' not running
[ 33.254701] Bluetooth: MGMT ver 1.23
[ 33.283252] Bluetooth: RFCOMM TTY layer initialized
[ 33.283290] Bluetooth: RFCOMM socket layer initialized
[ 33.283314] Bluetooth: RFCOMM ver 1.11
[ 33.315381] redpine_91x: <==== Interface UP ====>
[ 33.315531] redpine_91x: rsi_mac80211_bss_info_changed: Change of ERP INFO: 0
[ 33.315557] redpine_91x: rsi_mac80211_bss_info_changed: Sending vap updates....
[ 33.344331] redpine_91x: <==== Interface DOWN ====>
[ 33.350305] redpine_91x: <==== Interface UP ====>
[ 33.351452] redpine_91x: rsi_mac80211_bss_info_changed: Change of ERP INFO: 0
[ 33.351476] redpine_91x: rsi_mac80211_bss_info_changed: Sending vap updates....
[ 37.288890] redpine_91x: <==== Interface DOWN ====>
[ 37.290291] redpine_91x: <==== Interface UP ====>
[ 37.290346] redpine_91x: rsi_mac80211_bss_info_changed: Change of ERP INFO: 0
[ 37.290356] redpine_91x: rsi_mac80211_bss_info_changed: Sending vap updates....
[ 37.357210] wlan0: authenticate with c4:46:19:1f:f5:f5 (local address=88:da:1a:7c:d3:7c)
[ 37.357234] wlan0: send auth to c4:46:19:1f:f5:f5 (try 1/3)
[ 37.360392] wlan0: authenticated
[ 37.363997] wlan0: associate with c4:46:19:1f:f5:f5 (try 1/3)
[ 37.367340] wlan0: RX AssocResp from c4:46:19:1f:f5:f5 (capab=0x431 status=0 aid=3)
[ 37.368455] wlan0: associated
[ 37.386302] redpine_91x: EAPOL 4 confirm
[ 38.771804] rtc-m41t80 0-0068: OF bit is still set, kickstarting clock.
[ 132.099318] edt_ft5x06 2-0038: Unable to fetch data, error: -6
[ 231.813174] thermal thermal_zone3: Unable to get temperature, disabling!
[ 1100.014279] edt_ft5x06 2-0038: Unable to fetch data, error: -6
[ 1119.566458] bq25890-charger 3-006a: Upstream supply changed: 1.
[ 1119.566960] bq25890-charger 3-006a: Disabling OTG_EN pin
[ 1119.575766] bq25890-charger 3-006a: Upstream supply changed: 1.
[ 1119.575932] bq25890-charger 3-006a: Disabling OTG_EN pin
[ 1119.701818] bq25890-charger 3-006a: Upstream supply changed: 1.
[ 1119.702324] bq25890-charger 3-006a: Disabling OTG_EN pin
[ 1119.885801] bq25890-charger 3-006a: Upstream supply changed: 1.
[ 1119.886481] bq25890-charger 3-006a: Disabling OTG_EN pin
[ 1120.055973] bq25890-charger 3-006a: Upstream supply changed: 1.
[ 1120.056640] bq25890-charger 3-006a: Disabling OTG_EN pin
[ 1136.096589] edt_ft5x06 2-0038: Unable to fetch data, error: -6
[ 1832.591237] edt_ft5x06 2-0038: Unable to fetch data, error: -6
[ 2554.402502] edt_ft5x06 2-0038: Unable to fetch data, error: -6
[ 4111.349811] edt_ft5x06 2-0038: Unable to fetch data, error: -6
[ 5157.508927] bq25890-charger 3-006a: Upstream supply changed: 0.
[ 5157.508969] bq25890-charger 3-006a: Disabling OTG_EN pin
[ 5157.516148] tps6598x 0-003f: The interrupt is masked , how did it fire ?? f0046dffbfeffff
[ 5157.516416] bq25890-charger 3-006a: Upstream supply changed: 0.
[ 5157.516445] bq25890-charger 3-006a: Disabling OTG_EN pin
[ 5157.521383] bq25890-charger 3-006a: Upstream supply changed: 0.
[ 5157.521415] bq25890-charger 3-006a: Disabling OTG_EN pin
[ 5157.623801] bq25890-charger 3-006a: Upstream supply changed: 0.
[ 5157.623833] bq25890-charger 3-006a: Disabling OTG_EN pin
[ 5172.405675] edt_ft5x06 2-0038: Unable to fetch data, error: -6
purism@pureos:~$
