Hi !
I find it difficult to accept the correct timing for a conversation via “Calls”, because the ringtone continues to ring when i accepted incoming calls.
My friends are very irritated when they call me. Is it a problem of the app or in my settings ?
It happens with my L5, too. I hear a superfluous ring or two after the call connection is established. But then it stops ringing.
Edit: Sometimes, but not every time. (I think. I don’t use calling very much. Lol!)
Yes, it stops after the last started sound is finished … that the “timing”-problem.
This are small but really annoying bug. Ok, no settings problem - thanks for your feedback.
I am looking for an update on this issue. I have phone conversations with people but if someone else calls, i can’t ignore it or not accept the call. The phone hangs up on my first caller and just keeps ringing and buzzing. It doesn’t stop. I have to restart the phone to correct the issue. Of course, this is very annoying and the people who are trying to talk to me are also annoyed. This kind of issue has to be fixed to make the pain point of using this device tolerable IMHO. Thank you for any help.
