For those who use only tap to click and want make touchpad hold still when pressing. I didn’t see any official guide how to do it. So here is short description how to do it:
You will need just phillips screwdriver and few minutes.
- Turn off your Librem 13, disconnect the charger.
- Unscrew all 12 screws at the bottom and take off the case.
- Find metal bar holding the bottom of touchpad.
- Unscrew the 3 screws, flip the bar and screw it back.
- Put back the case (note 2 central screws are longer and some screws don’t go exactly vertical, but with some angle)
- Check if the touchpad does not click anymore.
