Hello everybody,
I just noticed that the layout for “Settings->Privacy->Localization Services” is not being rendered correctly, the toggle is not visible when the phone is kept vertical. Is this a known bug?
Hello everybody,
works for me can you take a screenshot?
i remember for me it used to do that but was a while ago. Maybe it has something to do with the translation.
You can download Mobile Settings and try to toggle the Compositor setting as a work around and maybe it will scale so you can see the setting.
Ok, I enabled the compositor and now I can see the toggle, thanks! I hope they will fix this anyway
