Touchpad mouse not moving
Hi
I just done a new install of PureOS
the mouse/pointer shows on the screen.
but it does not move when using touch pad
when an external mouse is connected the pointer moves.
Any suggestions?
Yes, press Fn+F1 to activate your touchpad.
@mladen
You are a star!!
Many thanks
You put the “Solution” on the wrong post but for a topic with 4 posts people will work it out.
