Track Mobile Data Usage
I’ve been playing around with the following, and I’m still testing, but I’ll share some of the basics I (think I) have learned so far. Corrections and suggestions are welcome.
  1. vnstat - to display stats in the terminal
The vnstat package creates a table of data stats in the terminal:
sudo apt install vnstat
See vnstat options with the `--longhelp` parameter:
purism@pureos:~$ vnstat --longhelp
vnStat 2.6 by Teemu Toivola <tst at iki dot fi>
Query:
      -q,  --query                 query database
      -s,  --short                 use short output
      -5,  --fiveminutes [limit]   show 5 minutes
      -h,  --hours [limit]         show hours
      -hg, --hoursgraph            show hours graph
      -d,  --days [limit]          show days
      -m,  --months [limit]        show months
      -y,  --years [limit]         show years
      -t,  --top [limit]           show top days
      -b,  --begin <date>          set list begin date
      -e,  --end <date>            set list end date
      --oneline [mode]             show simple parsable format
      --json [mode] [limit]        show database in json format
      --xml [mode] [limit]         show database in xml format
Modify:
      --add                        add interface to database
      --remove                     remove interface from database
      --rename <name>              rename interface in database
      --setalias <alias>           set alias for interface
Misc:
      -i,  --iface <interface>     select interface
      -?,  --help                  show short help
      -D,  --debug                 show some additional debug information
      -v,  --version               show version
      -tr, --traffic [time]        calculate traffic
      -l,  --live [mode]           show transfer rate in real time
      -ru, --rateunit [mode]       swap configured rate unit
      --limit <limit>              set output entry limit
      --style <mode>               select output style (0-4)
      --iflist                     show list of available interfaces
      --dbdir <directory>          select database directory
      --locale <locale>            set locale
      --config <config file>       select config file
      --showconfig                 dump config file with current settings
      --longhelp                   show this help
See also "man vnstat" for longer descriptions of each option.
SOME BASIC USAGE
Designate an interface.
To track mobile data usage, add its interface name to vnstat.
To find the interface name for the mobile data connection:
Method 1: Run the command ip address in the terminal. You’ll see entries for lo, usb0, wlan0, and wwan0. Observe the listed IP addresses; it should be obvious which one is the mobile connection: wwan0.
Method 2: Open the What IP app (package name “whatip”) when you have WiFi and Cellular both enabled. Again: it’s wwan0.
The command to add the wwan0 interface is: vnstat -i wwan0
Running the basic command vnstat in terminal generates a table (for the day) of all the current interfaces:
                      rx      /      tx      /     total    /   estimated
 usb0: Not enough data available yet.
 wlan0:
       2025-06     20.53 MiB  /    2.32 MiB  /   22.85 MiB  /   37.08 MiB
         today     20.53 MiB  /    2.32 MiB  /   22.85 MiB  /   52.64 MiB
 wwan0:
       2025-06      3.28 MiB  /  163.14 KiB  /    3.44 MiB  /    4.94 MiB
         today      3.28 MiB  /  163.14 KiB  /    3.44 MiB  /    7.92 MiB
purism@pureos:~$
We can further refine the output by adding a parameter, e.g. hours, days, months, or live:
vnstat -h
vnstat -d
vnstat -m
vnstat -l
Example:
purism@pureos:~$ vnstat -m
 wlan0  /  monthly
        month        rx      |     tx      |    total    |   avg. rate
       2025-06     20.53 MiB |    2.32 MiB |   22.85 MiB |      127 bit/s
     estimated     34.61 MiB |    2.47 MiB |   37.08 MiB |
purism@pureos:~$
To display mobile data stats for the month:
vnstat -i wwan0 -m
To display lan data stats for the month:
vnstat -i wlan0 -m
For a specific date range (begin & end):
vnstat -i wwan0 -b YYYY-MM-DD -e YYYY-MM-DD
To display the combined lan and mobile data usage for a month:
vnstat -i wlan0+wwan0 -m
To edit the configuration file: sudo nano /etc/vnstat.conf
This setting in the configuration file allows you to set the rotate date:
# on which day should months change
MonthRotate 1
MonthRotateAffectsYears 0
To just view the present configuration: vnstat --showconfig
  1. vnstati - to output a graphical version of the stats
This outputs the vnstat data to a .png file as a nice graphic:
sudo apt install vnstati
See vnstati options:
vnStat image output 2.6 by Teemu Toivola <tst at iki dot fi>
      -5,  --fiveminutes [limit]   output 5 minutes
      -h,  --hours [limit]         output hours
      -hg, --hoursgraph            output hours graph
      -d,  --days [limit]          output days
      -m,  --months [limit]        output months
      -y,  --years [limit]         output years
      -t,  --top [limit]           output top days
      -s,  --summary               output summary
      -hs, --hsummary              output horizontal summary with hours
      -vs, --vsummary              output vertical summary with hours
      -nh, --noheader              remove header from output
      -ne, --noedge                remove edge from output
      -nl, --nolegend              remove legend from output
      -o,  --output <file>         select output filename
      -c,  --cache <minutes>       update output only when too old
      -?,  --help                  this help
      --limit <limit>              set list entry limit
      --style <mode>               select output style (0-3)
      --altdate                    use alternative date location
      --headertext <text>          specify header text string
      --transparent [enabled]      toggle background transparency
See also "man vnstati".
USAGE
These commands place the graphic in your home folder, but you can designate a different directory and name:
RESULT
wlan0 (wifi data)
DataUsageWLAN0
wwan0 (mobile data)
DataUsageWWAN0
You can create a desktop launcher if you want to automatically generate and open the image file with a single tap from the app grid.
References:
https://www.howtoforge.com/tutorial/vnstat-network-monitoring-ubuntu/
https://www.cyberciti.biz/faq/linux-unix-adding-network-interface-to-vnstat-to-database-for-monitoring/
EDIT / Additonal reference:
https://www.geeksforgeeks.org/linux-unix/vnstat-command-in-linux-with-examples/
I see that vnstat has been mentioned several times in the forum history.
Nice work.
So does that somehow poll the kernel periodically and then squirrel the information away in its own database? If so, what does it use for a database?
Possibly this: /var/lib/vnstat.db
It would be really helpful if somebody could package vnstat/vnstati into a user-friendly graphical mobile app, with lots of selection boxes/buttons to choose various durations, interface names, and so on. (That somebody isn’t me, unfortunately…)
No doubt very useful for those who want or need to watch their mobile data consumption.
Probably.
Probably an SQLite database?
The reason I ask is because that determines both the dependencies and how hefty the required resources would be to run the package.
If it is SQLite then at least SQLite is already installed on the Librem 5.
In my case, I also already have installed the sqlite3 command on my Librem 5 - which allows command line access to an SQLite database. At the very least that would confirm that vnstat is using an SQLite database - and you could do some really simple tasks like giving you a warning as you approach your mobile plan’s monthly limit (over and above what warnings your provider might give you).
I just opened it in DB Browser for SQLite. It obviously doesn’t have much data in it yet (90kb), as I only installed it today.
By the way, the actual vnstat and vnstati packages are quite small, and use very little space when installed. Just a few tens of megabytes.
