The purpose of this topic is to discuss True Wireless Stereo (TWS) Earbuds that come with a Smart Charging Case featuring a touchscreen, which limits or eliminates the need for an iOS or Android app to access most or all features.
The smart case features a 1.45 inch touch screen, wireless charging, USB-C fast-charging, and magnets (to hold the earbuds inside the case and to hold the lid closed).
The iOS or Android app is required for the following features:
Update firmware of earbuds and smart case (requires that the app has internet connectivity)
Customize ANC settings:
Enable Adaptive ANC (automatically adjusts the ANC level based on the surrounding noise level) or Disable Adaptive ANC and manually adjust sensitivity using slider
Leakage Compensation (check leakage status and adjust the ANC level in real-time)
Ear Canal Compensation
Ear Canal Test
Manually adjust sensitivity of Ambient Aware mode using slider
Create custom Equalizer mode (only one custom mode can be used by smart case)
Enable/Disable option to Preserve Settings for Spacial Sound (preserve settings keeps Spacial Sound mode setting; disabling this disables Spacial Sound when earbuds are shutdown)
Enable/Disable Earbud Gestures with limited customization if enabled
Manually adjust VoiceAware sensitivity using slider
Enable/Disable Smart Audio & Video (enabled by default) and switch between 2 modes:
Audio Mode (optimized for music and enabled by default)
Video Mode (optimized for low latency)
Manually Configure SilentNow (does not affect smart case)
Enable/Disable Personal Sound Amplification and manually adjust left/right balance and gain (amplify situational sounds from your surroundings to stay aware of what is going on around you and enhance conversation)
Configure Voice Assistant
Enable/Disable Voice Prompts
Check My Best Fit (helps you get a good seal by playing music to detect any sound leakage from wearing the earbuds loosely or using wrong sized ear tips)
Enable/Disable Max Volume Limiter (protect your hearing with a volume limit)
Smart Case Settings:
Upload custom wallpaper to smart case
Manually adjust smart case auto-sleep time using slider (from 1 second to 60 seconds)
Enable/Disable Message Preview (if Message Notification and Message Preview are enabled, the actual content of the message notification is displayed on the smart case)
Enable/Disable the following Feature Shortcuts pages on smart case:
Ambient Sound Control
Spacial Sound
Equalizer
VoiceAware
Auto Play & Pause
SilentNow
Power Saving modes:
Auto Standby (earbuds enter standby mode and automatically disable ANC if idle for 15 minutes to save power)
Auto Power Off (earbuds automatically power off in idle mode)
I bought a pair of JBL Tour Pro 2 last year, and I love them! I hope that competition will eventually bring the ability to use a Linux computer to manage firmware updates and other settings, but that is probably not happening anytime soon. I’m just glad that I can access all of these features without an iOS or Android device, and they sound really good too.
Yes, the JBL Tour Pro 2 earbuds work with the Librem 5; I’m using them right now to listen to an internet radio station using the Shortwave flatpak.
Are they open source? Can they be verified?
No, I don’t think so.
Do I trust them?
They have no network connectivity features, so I don’t feel like I need to trust them. What malicioius things could they even do? I can’t think of anything.
I borrowed a degoogled phone from a friend and verified that the JBL Headphones Android app can be used without internet connectivity, whereas the Sony Headphones Android app requires an internet connection when you click the buttons to agree to TOS and Privacy policy, which makes me distrustful of Sony products.
Besides the PineBuds Pro, which do not have a touchscreen-enabled smart case, there aren’t any other open source TWS earbuds yet. If Purism decides to make their own TWS earbuds, I will absolutely buy them.
But even if there is a nice free software linux app for controling them, the touchscreen-enabled smart case is a game-changer for convenience and usability that makes for a platform-agnostic product. That is what should be the focus of companies like Purism when making products like TWS earbuds. If a non-linux user were looking for such a product, the requirement for a free software linux app would be a strong deterrent.
Can you elaborate on what connects to what and how?
Even without internet connectivity, a comprehensive investigation of the security and privacy risks would have to consider what RF transmissions are involved.
I’m not an expert here, just a user. If my understanding is correct, TWS earbuds only connect to each other, the charging case, and the transmitting device - all using Bluetooth; there is no Wifi involved.
Bluetooth itself seems to be greatly lacking in security. Using Bluetooth devices is inherently risky, to an extent, and it’s a risk that I currently accept.
