Trying to delete zoom
trying to delete zoom dont feel comfortable with it on my laptop its not funny
Since this is the in PureOS section of the forums, I assume you are running PureOS, and probably on a Purism computer.
If Zoom is on the machine, since it is not in the Purism repos, it was likely installed as a Flakpak.
Try running this command:
sudo flatpak uninstall us.zoom.Zoom (if installed system-wide)
flatpak uninstall us.zoom.Zoom (if installed under the user)
Or you can just run them both :slight_smile:
Not necessarily. zoom.us gives a deb package that installs on PureOs (that is how I installed it on L13).
In that case a
sudo dpkg --remove zoom
or
sudo dpkg --purge zoom
to remove configuration files as well.
