Within Discourse there is an automatic typographer module, so that when I type, for example, .. I get instead … (ellipsis) and when I type -- I get instead – (en dash) and who knows what other automatic supposedly helpful substitutions are made.
These are particularly unhelpful in a forum that has frequent references to shell commands, and may even be dangerous if commands are cut-and-pasted out of a forum into a shell window.
I think this same module also provides so-called smartquote functionality, and again that is almost certainly unhelpful with shell commands.
It is true that all of this is disabled for text that appears inside backquotes (or if the user judiciously uses backslash escapes). However not every user knows that that is necessary.
It seems that it is possible to disable the markdown typographer by configuration but that it is all-or-none. That is, I don’t think it is possible to have the markdown typographer enabled but disable all of the above problematic substitutions, leaving only the harmless or useful substitutions.
I move therefore that the markdown typographer be disabled.
Thoughts?
