$ git clone https://review.coreboot.org/coreboot
Cloning into 'coreboot'...
remote: Counting objects: 11, done
remote: Total 439577 (delta 0), reused 439577 (delta 0)
Receiving objects: 100% (439577/439577), 108.14 MiB | 1.56 MiB/s, done.
Resolving deltas: 100% (342452/342452), done.
Checking out files: 100% (15699/15699), done.
$ cd coreboot/
$ make crossgcc-i386 CPUS=$(nproc)
Welcome to the coreboot cross toolchain builder v2d22d335dc (2019-03-22)
Building toolchain using 4 thread(s).
Target architecture is i386-elf
Found compatible Ada compiler, enabling Ada support by default.
Downloading and verifing tarballs ...
* gmp-6.1.2.tar.xz (downloading from https://ftpmirror.gnu.org/gmp/gmp-6.1.2.tar.xz)... 100%... hash verified (9dc6981197a7d92f339192eea974f5eca48fcffe)
* mpfr-4.0.2.tar.xz (downloading from https://ftpmirror.gnu.org/mpfr/mpfr-4.0.2.tar.xz)... 100%... hash verified (52c1f2a4c9a202f46cf3275a8d46b562aa584208)
* mpc-1.1.0.tar.gz (downloading from https://ftpmirror.gnu.org/mpc/mpc-1.1.0.tar.gz)... 100%... hash verified (b019d9e1d27ec5fb99497159d43a3164995de2d0)
* binutils-2.32.tar.xz (downloading from https://ftpmirror.gnu.org/binutils/binutils-2.32.tar.xz)... 100%... hash verified (cd45a512af1c8a508976c1beb4f5825b3bb89f4d)
* gcc-8.2.0.tar.xz (downloading from https://ftpmirror.gnu.org/gcc/gcc-8.2.0/gcc-8.2.0.tar.xz)... 100%... hash verified (19926bdb6c4b58891015929853d41aeff019d400)
Downloaded tarballs ... ok
Unpacking and patching ...
* gmp-6.1.2.tar.xz
o gmp-6.1.2_freebsd-configure.patch
* mpfr-4.0.2.tar.xz
* mpc-1.1.0.tar.gz
o binutils-2.32_mips-gold.patch
o binutils-2.32_no-bfd-doc.patch
* gcc-8.2.0.tar.xz
o gcc-8.2.0_ada-musl_workaround.patch
o gcc-8.2.0_gnat.patch
o gcc-8.2.0_libgcc.patch
o gcc-8.2.0_nds32_ite.patch
Unpacked and patched ... ok
Building packages ...
Building GMP v6.1.2 for host ... ok
Building MPFR v4.0.2 for host ... ok
Building MPC v1.1.0 for host ... ok
Building BINUTILS v2.32 for target ... ok
Building GCC v8.2.0 for target ... ok
Packages built ... ok
Copied EDK2 tools template ... ok
Cleaning up temporary files... ok
But running the purism script yields
Welcome to the coreboot cross toolchain builder v1.50 (October 15th, 2017)
* gmp-6.1.2.tar.xz (cached)... hash verified (9dc6981197a7d92f339192eea974f5eca48fcffe)
* mpfr-3.1.5.tar.xz (cached)... hash verified (c0fab77c6da4cb710c81cc04092fb9bea11a9403)
* mpc-1.0.3.tar.gz (cached)... hash verified (b8be66396c726fdc36ebb0f692ed8a8cca3bcc66)
* binutils-2.29.1.tar.xz (cached)... hash verified (172244a349d07ec205c39c0321cbc354c125e78e)
* gcc-6.3.0.tar.bz2 (cached)... hash verified (928ab552666ee08eed645ff20ceb49d139205dea)
* gmp-6.1.2.tar.xz
* mpfr-3.1.5.tar.xz
* mpc-1.0.3.tar.gz
o binutils-2.29.1_mips-gold.patch
o binutils-2.29.1_no-bfd-doc.patch
* gcc-6.3.0.tar.bz2
o gcc-6.3.0_ada-musl_workaround.patch
o gcc-6.3.0_ada-raise.patch
o gcc-6.3.0_elf_biarch.patch
o gcc-6.3.0_gnat.patch
o gcc-6.3.0_libgcc.patch
o gcc-6.3.0_memmodel.patch
o gcc-6.3.0_nds32_ite.patch
o gcc-6.3.0_no-p-var.patch
o gcc-6.3.0_pointer_integer.patch
o gcc-6.3.0_riscv.patch
Building MPFR v3.1.5 for host ... ok
Building MPC v1.0.3 for host ... ok
Building BINUTILS v2.29.1 for target ... ok
Building GCC v6.3.0 for target ... failed. Check 'build-i386-elf-GCC/build.log'.
make[2]: *** [Makefile:26: build_gcc] Error 1
make[1]: *** [Makefile:48: build-i386] Error 2
make: *** [util/crossgcc/Makefile.inc:46: crossgcc-i386] Error 2
So it seems to be something that is introduced by this section in the script
git fetch origin
git fetch purism
git fetch purism --tags
# checkout master so we can delete the librem branch
git checkout master
# delete it, in case it's our first run, do || true
git branch -D librem || true
git checkout -b librem "$COREBOOT_TAG"
# need to update submodules after the checkout
git sup
what OS are you building from, and what is the host gcc version? It’s possible your host gcc is failing to build the older gcc 6.3 specified by the tagged version of coreboot used in the build script
