It’s been a while since I asked, and unfortunately have not gotten a response. I just need to know how much it will take for me to get a new replacement display for a Librem 11. I would like to fix it and keep using it.
Your patience is all that is required.
Hmm… I remember asking about this a long time ago but don’t recall the response, so it may have fallen off the radar. Purism isn’t the ODM for the Librem 11 v1 and the mechanical design don’t use standard dimensions so, IIRC, Purism has yet to locate a feasible part vendor for screen replacement.
But I can try to sweep the dust off this inquiry. What’s the ticket number @nerd7473?
I went ahead and sent another inquiry since I suspect maybe Librem Mail was having issues near the time. But the original ticket number was: #6388
