I’m being unable to switch wifi network. If I try I get disconnected from the old one but not connected to the new one. The applet on the right upper bar stops working and I can not open Settings app. If the app was previously opened, then the wifi disappears from there.
I saw this in /var/log/messages:
Nov 22 14:47:49 goedel gnome-shell[2818]: Object St.Widget (0x56407af3d840), has been already deallocated — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
Nov 22 14:47:49 goedel org.gnome.Shell.desktop[2818]: == Stack trace for context 0x564079a661d0 ==
Nov 22 14:47:49 goedel org.gnome.Shell.desktop[2818]: #0 56407a8391f0 i resource:///org/gnome/shell/ui/modalDialog.js:93 (7f5f190f0430 @ 22)
Nov 22 14:47:49 goedel org.gnome.Shell.desktop[2818]: #1 7ffc915190f0 b resource:///org/gnome/gjs/modules/_legacy.js:82 (7f5f190b0b80 @ 71)
Nov 22 14:47:49 goedel org.gnome.Shell.desktop[2818]: #2 56407a839138 i resource:///org/gnome/gjs/modules/_legacy.js:39 (7f5f190b08b0 @ 215)
Nov 22 14:47:49 goedel org.gnome.Shell.desktop[2818]: #3 56407a8390a8 i resource:///org/gnome/shell/ui/status/network.js:767 (7f5f189e21f0 @ 409)
Nov 22 14:47:49 goedel org.gnome.Shell.desktop[2818]: #4 7ffc9151a820 b resource:///org/gnome/gjs/modules/_legacy.js:82 (7f5f190b0b80 @ 71)
Nov 22 14:47:49 goedel org.gnome.Shell.desktop[2818]: #5 56407a839020 i resource:///org/gnome/shell/ui/modalDialog.js:168 (7f5f190f09d0 @ 92)
Nov 22 14:47:49 goedel org.gnome.Shell.desktop[2818]: #6 7ffc9151b790 b resource:///org/gnome/gjs/modules/_legacy.js:82 (7f5f190b0b80 @ 71)
Nov 22 14:47:49 goedel org.gnome.Shell.desktop[2818]: #7 7ffc9151c3a0 b self-hosted:975 (7f5f190f01f0 @ 392)
Nov 22 14:47:49 goedel org.gnome.Shell.desktop[2818]: #8 7ffc9151d740 b resource:///org/gnome/gjs/modules/tweener/tweener.js:208 (7f5f190db9d0 @ 54)
Nov 22 14:47:49 goedel org.gnome.Shell.desktop[2818]: #9 7ffc9151d890 b resource:///org/gnome/gjs/modules/tweener/tweener.js:342 (7f5f190dba60 @ 1742)
Nov 22 14:47:49 goedel org.gnome.Shell.desktop[2818]: #10 7ffc9151d940 b resource:///org/gnome/gjs/modules/tweener/tweener.js:355 (7f5f190dbaf0 @ 100)
Nov 22 14:47:49 goedel org.gnome.Shell.desktop[2818]: #11 7ffc9151d9d0 b resource:///org/gnome/gjs/modules/tweener/tweener.js:370 (7f5f190dbb80 @ 10)
Nov 22 14:47:49 goedel org.gnome.Shell.desktop[2818]: #12 7ffc9151da50 I resource:///org/gnome/gjs/modules/signals.js:128 (7f5f190c18b0 @ 386)
Nov 22 14:47:49 goedel org.gnome.Shell.desktop[2818]: #13 7ffc9151db00 b resource:///org/gnome/shell/ui/tweener.js:244 (7f5f190d99d0 @ 159)
Nov 22 14:47:49 goedel org.gnome.Shell.desktop[2818]: #14 7ffc9151dbd0 b resource:///org/gnome/gjs/modules/_legacy.js:82 (7f5f190b0b80 @ 71)
Nov 22 14:47:49 goedel org.gnome.Shell.desktop[2818]: #15 7ffc9151dc70 b resource:///org/gnome/shell/ui/tweener.js:219 (7f5f190d9940 @ 15)
Nov 22 14:47:49 goedel gnome-shell[2818]: clutter_actor_destroy: assertion 'CLUTTER_IS_ACTOR (self)' failed
I’m using PureOS amber 9.0 and it’s up to date.
I also have problems after suspending, not sure if it may be related to this.
Any idea on how to fix it?
Thanks.
