Unassigned pushbuttons (and LEDs), features request, opinions?
IMHO this will be nice to have several pushbuttons on one or more side (in side_frame, not on front and not on rear) of phone with user assignable functions.
User can assign such functions as play, pause/stop, next or previous track, accept call, reject call, etc…
This allow to activate required function even without unlocking screen.
The pushbutton(s) must not to protrude from side_frame flatness to eliminate unwanted activation when holding and transportation.
IMHO flatness of side_frame and flatness of pushbutton (when not pressed) must be the same (equal, to form single surface).
And such pushbuttons must have large enough diameter (more than 6 mm) for convenient manipulating (pushing) by human fingers.
Of course dedicated lock slider switch necessary to logically lock this pushbuttons from acting when user in doubt about unwanted occasional push.
(e.g. cusped objects in the bag with phone)
It may be groundbreaking to inflict braille character (or some like) on pushbutton top to simplify blind using.
It’s not certain to me how many and which side pushbuttons should be. So invite to offer your opinions.
Below the scheme to simplify formulate and exclude uncertainity.
Side naming. Phone view from front (screen).
          N (North)
          ________
W (West) |  front | E (East)
         | screen |
         |________|
          S (South)
Expression elements.
Expression similar to equation. Left part correspond to side naming and right part correspond to quantity.
There is combinatorial operations.
“+” “summing” sides without order accounting (W+E=8 mean exactly 8 pushbuttons in sum for W and E sides (i.e. both long sides)
“^” exclusively one side (W^E=5 mean exactly 5 pushbuttons on one of long (W or E) side only)
“|” exchange sides (N|W=5|3 mean 5 pushbuttons on one long side and 3 pushbuttons on opposite long side)
“?” before quantity mean “I’m not sure about exact quantity” (more “?” more unsure) (N=?1 mean 1 pushbutton on N side, but I’m not sure
“+” after quantity mean not less than (W=5+ mean not less than 5 pushbuttons on W side)
“-” after quantity mean not more than (E=3- mean not more than 3 pushbuttons on E side)
“~” before quantity mean about (W+E=~8 mean about 8 pushbuttons in sum for long sides)
“…” between numbers mean quantity interval (N+S+W+E=~8…13 mean overall pushbuttons quantity is about from 8 to 13)
Probably not all cases can be expressed via this expressions, so if not so lazy, write expanded opinion :slight_smile:
IMHO nice to have several user assignable RGB LEDs on front side (probably above screen area) or maybe inside side frame emiting light to side.
User can assign this LEDs to indicating various kinds of events: SMS arrival, missed call, e-mail arrival, new message, loss of network, alarms, etc.
This allow to control main and necessary events even with main screen fully off, and save battery energy.
Use same equation for LEDs with addition of F (Front) and B (Back,Rear) sides.
IMHO i.MX8M GPIO1.IO[0]…GPIO1.IO[15] is preferred for pushbuttons connections because it has no multiplexing with other functions, hence it will not interfere with any specific peripheral in present and future designed devices.
And for pushbuttons GPIO1.IO[0]…GPIO1.IO[7] better to use (unless used for IRQ signal from external peripheral module), because it has dedicated connection to interrupt controller.
For RGB LEDs seems better to use specialized control driver ICs which already has current driver and digital color (RGB component) input via SPI or I2C.
Resume:
My opinion is W|E=5+|5- I.e. Five or more pushbuttons on one long side plus not more than five pushbuttons on opposite side.
And with no sentence about short sides, but most probably 0 pushbuttons there.
For LED: F=~3…5 I.e. about 3 to 5 LEDs on front.
That will be fantastic… even if it doesnt/can’t happen 'til the next version phone after the Librem 5.
Customizable series of indicator LEDs… Absolutely!
Customizable buttons, Yes please.
And surely someone will come up with software for this Librem 5 that allows a nap feature… such as "no alerts for the next X amount of hours, while I catnap "… even with finer cobtrols, such as ‘no alerts except for calls from my “favorited” contacts, for 3 hours’.
when i received my LG G3 i was a bit confused as it had just three buttons and all placed on the back.
found out: its the best you can have. you never press any buttom by accident either in pocket or by giving your phone someone to look at a pic (where everyone would hit one of the buttons at the side).
on the other hand i dont like buttons at all as these are the parts that make mobiles fragile. not only dust can come in, body structure is weakend (see the iphone problem lately) even the switch itself is a mechanical component which tends to break.
so no: i would be fine with 3 buttons: on, up, down.
Series? Pardon me? One multi-color status LED should suffice.
I mean… if they would do what everybody suggested, we would end up with…
A series of LEDs, a few unassigned extra buttons, a dozen of killswitches (for each sensor), the “classic” buttons, 3…6 cams (front, back, stereo, wide/zoom, infrared, …) + 2 flashes, finger print, a sliding hardware keyboard with a trackball, NFC, IR and rubber feet :sunglasses:
On a more serious note:
The existing buttons (+ and -) can in theory be repurposed. Like some camera apps do for zooming. Admittedly, this has some limits :slight_smile:
Another possibility would be to make real use of the gyroscope so you can shake and knock your phone and assign actions to that.
How about something I’ve not seen on any of my phones, but would require just 1 LED… if it could cycle through a variety of colors (notifications) while only requiring one LED? That could be a possibe feature, from a developer’s POV couldn’t it? (One color flash for missed call, another for missed email, etc… flashing in a sequence?)
This is standard for some years already. At least for my last two phones.
So I expect this in the librem 5 as well.
