Unstable wifi on Librem 14 with PureOS
Hello,
I am having wifi connectivity issues on a brand new Librem 14 and PureOS. I have done all system upgrades per the guides on official Purism sources.
I am using the “stock” wifi adapterb as installed on the Librem.
The connection drops intermittently and at time goes to normal speed or has extreme latency. I have done the DNS “fix” as per the FAQ and that helped temporarily.
Anyone else having the same issue and how can this be resolved?
Contact support. support@puri.sm
Is it better, if you stay very close to the WiFi router?
To a degree yes. I am working on replicating the issue. Oddly enough, when a reboot happens, the stability is fine for a period of time, then seems to wane.
