Anything but 6.3, I think, yes. 5.* and 6.0-6.2 shouldn’t be needed any more.
@joao.azevedo can confirm but I believe this is the way to go.
I started typing 'sudo rm /boot/vmlinuz-5.16.0-1-librem5 and give me : No such file or directory
What did I do wrong?
Then tried again with autoremove…
Maybe 5.16 is already removed?
From your last screenshot, I can see 6.1 and 6.2 still exist, plus possible 6.0 above it.
Try removing those too?
You can also remove the initrd files with the same versions. Those files are much larger so that will get you where you need to be even quicker.
Just as long as you don’t remove anything with 6.4 in it, as it looks like you are using that one now.
a total disaster. The Librem5 is dead. I turned it off and it’s not able anymore to turn on again: it continue to do a short vibration and blink with green led. It stopped to work. Can I throw it in the garbage now?
I am really fed up…
Push your Volume Down button at Boot. Can you take a Picture of the last Message, after enter your encryption password?
Edit: Mybe this helps: Low Disk Space on "boot" - #4 by Gavaudan
You should remove older kernels than 6.3. Source
My related post with more context to the start of the Matrix conversation
While it is very frustrating to break your OS, the phone can still be saved. Since something went wrong where the OS was not removing old kernels automatically, it was probably best to re-install the OS anyways.
Here are the instructions to reflash the OS: Reflashing the Phone
If you have data you want to save you can use Jumpdrive to access your files:
It’s on my TODO list to thoroughly document and/or safely automate this process, but here’s a very rough draft I just scraped together. Feel free to comment here or on the snippet itself. I do intend to eventually migrate this draft to official documentation material.
I do think documentation of a manual solution is a good step. Is there also a plan for this cleanup to be a part of the gui update process at some point? Part of the draw for me was the long term goal that this be a device for non-technical people in my life.
By “gui update process” are you referring to the PureOS Store? The developers would have to verify this, but IMO it could be possible to integrate a pre-installation hook to query free space in /boot and clean up old kernels as appropriate. Of course, this would assume a standard use-case of preferring only the newest successfully-installed kernel and could annoy folks that may be targeting a specific version.
I don’t envision a standalone GUI for this as, frankly, this maintenance step should be invisible to the end-user in the first place.
Correct. Though I’m not opposed to a different gui solution in the future, just looking for a solution for less technical people.
As for people targeting a specific version, that seems to me to be a more technical thing that can be dealt with via documentation and disabling or otherwise avoiding the default gui solution.
