Upgrade from amber, grub-efi / desktop-base hangs
Librem 15 ver. 3 tpm
Upgrading from Amber with the directions from Download PureOS and it seems to hang installing desktop-base / grub-efi
Setting up desktop-base (11.0.3) …
grub-efi* packages found, using 16/9 as default grub background ratio
Then hangs indefinitely. I’m not seeing any other errors.
You can try a fresh installation.
Probably some dektop- or graphics-related things got messed up for your current login session. Try pressing ctrl+alt+F3 or similar to get a fresh login prompt, then login there and try to continue what you were doing.
