This. If it’s not harder to you, I would suggest to make a fresh install. In this case you get a fresh system, without the old problems that might affect it. Upgrade is typically a very complicated procedure that can always go wrong (despite the best efforts of the developers).
Hi, thanks for your quick reply! What is your personal attitude with such big upgrades: do you better wait x months before you do it, but usually not more than y months after first release (i.e. because not being maintained any longer, no further security updates)? Kind regards,
I typically upgrade when I have a couple of free days in my life, in order to check that things work and leave time to fix it if necessary. Of course, I have to find this time before the security updates end. With Debian (on which PureOS is based) I never experience any problems though.
