How could I detect if an USB key is really 3.0. I see with f3write a write speed of 15 to 20 MB/s:
purism@pureos:~$ f3write /media/purism/3E27-549E/f3
F3 write 8.0
Copyright (C) 2010 Digirati Internet LTDA.
This is free software; see the source for copying conditions.
Free space: 117.17 GB
Creating file 1.h2w ... OK!
Creating file 2.h2w ... OK!
Creating file 3.h2w ... OK!
Creating file 4.h2w ... 2.67% -- 14.15 MB/s -- 2:58:59
I have attached here the /var/log/syslog of the attach:
Jan 18 07:02:33 pureos kernel: [ 166.818806] bq25890-charger 3-006a: Upstream supply changed: 0.
Jan 18 07:02:33 pureos kernel: [ 166.818852] bq25890-charger 3-006a: Enabling OTG_EN pin
Jan 18 07:02:33 pureos kernel: [ 166.822229] bq25890-charger 3-006a: Upstream supply changed: 0.
Jan 18 07:02:33 pureos kernel: [ 166.822387] bq25890-charger 3-006a: Enabling OTG_EN pin
Jan 18 07:02:33 pureos kernel: [ 166.874187] bq25890-charger 3-006a: Upstream supply changed: 0.
Jan 18 07:02:33 pureos kernel: [ 166.874212] bq25890-charger 3-006a: Enabling OTG_EN pin
Jan 18 07:02:33 pureos kernel: [ 166.877746] bq25890-charger 3-006a: Upstream supply changed: 0.
Jan 18 07:02:33 pureos kernel: [ 166.877762] bq25890-charger 3-006a: Disabling OTG_EN pin
Jan 18 07:02:33 pureos kernel: [ 166.881558] tps6598x 0-003f: The interrupt is masked , how did it fire ?? 380100a
Jan 18 07:02:33 pureos kernel: [ 166.889837] bq25890-charger 3-006a: Upstream supply changed: 0.
Jan 18 07:02:33 pureos kernel: [ 166.889864] bq25890-charger 3-006a: Disabling OTG_EN pin
Jan 18 07:02:33 pureos kernel: [ 166.893360] bq25890-charger 3-006a: Upstream supply changed: 0.
Jan 18 07:02:33 pureos kernel: [ 166.893379] bq25890-charger 3-006a: Disabling OTG_EN pin
Jan 18 07:02:33 pureos usbguard-daemon[646]: uid=0 pid=606 result='SUCCESS' device.rule='allow id 1d6b:0002 serial "xhci-hcd.5.auto" name "xHCI Host Controller" hash "U1nFyrkh8NpSDAU6gmicq7SQ13ff+o3bmO/lcp19jvA=" parent-hash "KXlald6eHhgVzxEC+F9GN7dshRENSCw45OyqsVHzcD8=" via-port "usb3" with-interface 09:00:00 with-connect-type ""' device.system_name='/devices/platform/soc@0/38100000.usb/xhci-hcd.5.auto/usb3' type='Device.Insert'
Jan 18 07:02:33 pureos kernel: [ 166.933509] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
Jan 18 07:02:33 pureos kernel: [ 166.933539] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 3
Jan 18 07:02:33 pureos kernel: [ 166.933641] xhci-hcd xhci-hcd.5.auto: hcc params 0x0220fe6c hci version 0x110 quirks 0x0000000000000010
Jan 18 07:02:33 pureos kernel: [ 166.933678] xhci-hcd xhci-hcd.5.auto: irq 207, io mem 0x38100000
Jan 18 07:02:33 pureos kernel: [ 166.933797] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
Jan 18 07:02:33 pureos kernel: [ 166.933807] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 4
Jan 18 07:02:33 pureos kernel: [ 166.933816] xhci-hcd xhci-hcd.5.auto: Host supports USB 3.0 SuperSpeed
Jan 18 07:02:33 pureos kernel: [ 166.933871] bq25890-charger 3-006a: Upstream supply changed: 0.
Jan 18 07:02:33 pureos kernel: [ 166.933880] bq25890-charger 3-006a: Disabling OTG_EN pin
Jan 18 07:02:33 pureos kernel: [ 166.934009] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.05
Jan 18 07:02:33 pureos kernel: [ 166.934017] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 18 07:02:33 pureos kernel: [ 166.934024] usb usb3: Product: xHCI Host Controller
Jan 18 07:02:33 pureos kernel: [ 166.934029] usb usb3: Manufacturer: Linux 6.5.0-1-librem5 xhci-hcd
Jan 18 07:02:33 pureos kernel: [ 166.934034] usb usb3: SerialNumber: xhci-hcd.5.auto
Jan 18 07:02:33 pureos kernel: [ 166.934471] hub 3-0:1.0: USB hub found
Jan 18 07:02:33 pureos kernel: [ 166.934501] hub 3-0:1.0: 1 port detected
Jan 18 07:02:33 pureos kernel: [ 166.934865] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
Jan 18 07:02:33 pureos kernel: [ 166.934964] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.05
Jan 18 07:02:33 pureos kernel: [ 166.934972] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 18 07:02:33 pureos kernel: [ 166.934979] usb usb4: Product: xHCI Host Controller
Jan 18 07:02:33 pureos kernel: [ 166.934984] usb usb4: Manufacturer: Linux 6.5.0-1-librem5 xhci-hcd
Jan 18 07:02:33 pureos kernel: [ 166.934989] usb usb4: SerialNumber: xhci-hcd.5.auto
Jan 18 07:02:33 pureos kernel: [ 166.946130] hub 4-0:1.0: USB hub found
Jan 18 07:02:33 pureos kernel: [ 166.946175] hub 4-0:1.0: 1 port detected
Jan 18 07:02:33 pureos kernel: [ 166.946769] xhci-hcd xhci-hcd.5.auto: remove, state 1
Jan 18 07:02:33 pureos kernel: [ 166.946785] usb usb4: USB disconnect, device number 1
Jan 18 07:02:33 pureos kernel: [ 166.947165] bq25890-charger 3-006a: Upstream supply changed: 0.
Jan 18 07:02:33 pureos kernel: [ 166.947178] bq25890-charger 3-006a: Disabling OTG_EN pin
Jan 18 07:02:33 pureos usbguard-daemon[646]: uid=0 pid=606 result='SUCCESS' device.system_name='/devices/platform/soc@0/38100000.usb/xhci-hcd.5.auto/usb3' target.new='allow' device.rule='allow id 1d6b:0002 serial "xhci-hcd.5.auto" name "xHCI Host Controller" hash "U1nFyrkh8NpSDAU6gmicq7SQ13ff+o3bmO/lcp19jvA=" parent-hash "KXlald6eHhgVzxEC+F9GN7dshRENSCw45OyqsVHzcD8=" via-port "usb3" with-interface 09:00:00 with-connect-type ""' target.old='allow' type='Policy.Device.Update'
Jan 18 07:02:33 pureos kernel: [ 166.951018] xhci-hcd xhci-hcd.5.auto: USB bus 4 deregistered
Jan 18 07:02:33 pureos kernel: [ 166.951044] xhci-hcd xhci-hcd.5.auto: remove, state 1
Jan 18 07:02:33 pureos kernel: [ 166.951055] usb usb3: USB disconnect, device number 1
Jan 18 07:02:33 pureos kernel: [ 166.952082] xhci-hcd xhci-hcd.5.auto: USB bus 3 deregistered
Jan 18 07:02:33 pureos usbguard-daemon[646]: Device insert exception: SysFSDevice: descriptors: No such file or directory
Jan 18 07:02:33 pureos usbguard-daemon[646]: SysFSDevice: descriptors: No such file or directory
Jan 18 07:02:33 pureos usbguard-daemon[646]: Rejecting device at syspath=/devices/platform/soc@0/38100000.usb/xhci-hcd.5.auto/usb4
Jan 18 07:02:33 pureos usbguard-daemon[646]: USB Device Exception: SysFSDevice: (_sysfs_dirfd = open((G_sysfs_root + _sysfs_path).c_str(), O_PATH|O_DIRECTORY)) < 0: No such file or directory
Jan 18 07:02:33 pureos usbguard-daemon[646]: SysFSDevice: (_sysfs_dirfd = open((G_sysfs_root + _sysfs_path).c_str(), O_PATH|O_DIRECTORY)) < 0: No such file or directory
Jan 18 07:02:33 pureos usbguard-daemon[646]: uid=0 pid=606 result='SUCCESS' device.rule='allow id 1d6b:0002 serial "xhci-hcd.5.auto" name "xHCI Host Controller" hash "U1nFyrkh8NpSDAU6gmicq7SQ13ff+o3bmO/lcp19jvA=" parent-hash "KXlald6eHhgVzxEC+F9GN7dshRENSCw45OyqsVHzcD8=" via-port "usb3" with-interface 09:00:00 with-connect-type ""' device.system_name='/devices/platform/soc@0/38100000.usb/xhci-hcd.5.auto/usb3' type='Device.Remove'
Jan 18 07:02:33 pureos kernel: [ 167.041555] bq25890-charger 3-006a: Upstream supply changed: 0.
Jan 18 07:02:33 pureos kernel: [ 167.041598] bq25890-charger 3-006a: Enabling OTG_EN pin
Jan 18 07:02:33 pureos kernel: [ 167.045072] bq25890-charger 3-006a: Upstream supply changed: 0.
Jan 18 07:02:33 pureos kernel: [ 167.045103] bq25890-charger 3-006a: Enabling OTG_EN pin
Jan 18 07:02:33 pureos kernel: [ 167.057021] phy phy-381f0040.usb-phy.1: vbus is error
Jan 18 07:02:33 pureos kernel: [ 167.062231] phy phy-381f0040.usb-phy.1: vbus is error
Jan 18 07:02:33 pureos kernel: [ 167.068630] bq25890-charger 3-006a: Upstream supply changed: 0.
Jan 18 07:02:33 pureos kernel: [ 167.068650] bq25890-charger 3-006a: Enabling OTG_EN pin
Jan 18 07:02:33 pureos kernel: [ 167.083159] bq25890-charger 3-006a: Upstream supply changed: 0.
Jan 18 07:02:33 pureos kernel: [ 167.083182] bq25890-charger 3-006a: Enabling OTG_EN pin
Jan 18 07:02:33 pureos kernel: [ 167.184232] bq25890-charger 3-006a: Upstream supply changed: 0.
Jan 18 07:02:33 pureos kernel: [ 167.184256] bq25890-charger 3-006a: Enabling OTG_EN pin
Jan 18 07:02:33 pureos kernel: [ 167.185519] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
Jan 18 07:02:33 pureos kernel: [ 167.185548] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 3
Jan 18 07:02:33 pureos kernel: [ 167.185661] xhci-hcd xhci-hcd.5.auto: hcc params 0x0220fe6c hci version 0x110 quirks 0x0000000000000010
Jan 18 07:02:33 pureos kernel: [ 167.185706] xhci-hcd xhci-hcd.5.auto: irq 207, io mem 0x38100000
Jan 18 07:02:33 pureos kernel: [ 167.185819] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
Jan 18 07:02:33 pureos kernel: [ 167.185831] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 4
Jan 18 07:02:33 pureos kernel: [ 167.185842] xhci-hcd xhci-hcd.5.auto: Host supports USB 3.0 SuperSpeed
Jan 18 07:02:33 pureos kernel: [ 167.186173] bq25890-charger 3-006a: Upstream supply changed: 0.
Jan 18 07:02:33 pureos kernel: [ 167.186186] bq25890-charger 3-006a: Enabling OTG_EN pin
Jan 18 07:02:33 pureos kernel: [ 167.186334] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.05
Jan 18 07:02:33 pureos kernel: [ 167.186343] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 18 07:02:33 pureos kernel: [ 167.186349] usb usb3: Product: xHCI Host Controller
Jan 18 07:02:33 pureos kernel: [ 167.186354] usb usb3: Manufacturer: Linux 6.5.0-1-librem5 xhci-hcd
Jan 18 07:02:33 pureos kernel: [ 167.186359] usb usb3: SerialNumber: xhci-hcd.5.auto
Jan 18 07:02:33 pureos kernel: [ 167.189901] hub 3-0:1.0: USB hub found
Jan 18 07:02:33 pureos kernel: [ 167.189965] hub 3-0:1.0: 1 port detected
Jan 18 07:02:33 pureos kernel: [ 167.192415] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
Jan 18 07:02:33 pureos kernel: [ 167.192592] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.05
Jan 18 07:02:33 pureos kernel: [ 167.192601] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 18 07:02:33 pureos kernel: [ 167.192607] usb usb4: Product: xHCI Host Controller
Jan 18 07:02:33 pureos kernel: [ 167.192612] usb usb4: Manufacturer: Linux 6.5.0-1-librem5 xhci-hcd
Jan 18 07:02:33 pureos kernel: [ 167.192618] usb usb4: SerialNumber: xhci-hcd.5.auto
Jan 18 07:02:33 pureos kernel: [ 167.195684] hub 4-0:1.0: USB hub found
Jan 18 07:02:33 pureos kernel: [ 167.195726] hub 4-0:1.0: 1 port detected
Jan 18 07:02:33 pureos kernel: [ 167.198304] bq25890-charger 3-006a: Upstream supply changed: 0.
Jan 18 07:02:33 pureos kernel: [ 167.198326] bq25890-charger 3-006a: Enabling OTG_EN pin
Jan 18 07:02:33 pureos usbguard-daemon[646]: uid=0 pid=606 result='SUCCESS' device.rule='allow id 1d6b:0003 serial "xhci-hcd.5.auto" name "xHCI Host Controller" hash "G/QjSJzB6wJUsQhzW88okvkIFDx1hMMGTAEgq65aNxs=" parent-hash "KXlald6eHhgVzxEC+F9GN7dshRENSCw45OyqsVHzcD8=" via-port "usb4" with-interface 09:00:00 with-connect-type ""' device.system_name='/devices/platform/soc@0/38100000.usb/xhci-hcd.5.auto/usb4' type='Device.Insert'
Jan 18 07:02:33 pureos usbguard-daemon[646]: uid=0 pid=606 result='SUCCESS' device.system_name='/devices/platform/soc@0/38100000.usb/xhci-hcd.5.auto/usb4' target.new='allow' device.rule='allow id 1d6b:0003 serial "xhci-hcd.5.auto" name "xHCI Host Controller" hash "G/QjSJzB6wJUsQhzW88okvkIFDx1hMMGTAEgq65aNxs=" parent-hash "KXlald6eHhgVzxEC+F9GN7dshRENSCw45OyqsVHzcD8=" via-port "usb4" with-interface 09:00:00 with-connect-type ""' target.old='allow' type='Policy.Device.Update'
Jan 18 07:02:34 pureos kernel: [ 168.052383] usb 3-1: new high-speed USB device number 2 using xhci-hcd
Jan 18 07:02:35 pureos kernel: [ 169.109241] usb 3-1: New USB device found, idVendor=058f, idProduct=6387, bcdDevice= 0.02
Jan 18 07:02:35 pureos kernel: [ 169.109267] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 18 07:02:35 pureos kernel: [ 169.109276] usb 3-1: Product: Mass Storage
Jan 18 07:02:35 pureos kernel: [ 169.109284] usb 3-1: Manufacturer: Generic
Jan 18 07:02:35 pureos kernel: [ 169.109291] usb 3-1: SerialNumber: A430786F
Jan 18 07:02:35 pureos kernel: [ 169.110249] usb 3-1: Device is not authorized for usage
Jan 18 07:02:35 pureos kernel: [ 169.118564] usb-storage 3-1:1.0: USB Mass Storage device detected
Jan 18 07:02:35 pureos kernel: [ 169.119970] scsi host1: usb-storage 3-1:1.0
Jan 18 07:02:35 pureos kernel: [ 169.121013] usb 3-1: authorized to connect
Jan 18 07:02:35 pureos usbguard-daemon[646]: uid=0 pid=606 result='SUCCESS' device.rule='block id 058f:6387 serial "A430786F" name "Mass Storage" hash "B+FqwLiWZRK/MDEKyQ6xbqPK5mG4GgVYyTlEI861WIk=" parent-hash "U1nFyrkh8NpSDAU6gmicq7SQ13ff+o3bmO/lcp19jvA=" via-port "3-1" with-interface 08:06:50 with-connect-type "unknown"' device.system_name='/devices/platform/soc@0/38100000.usb/xhci-hcd.5.auto/usb3/3-1' type='Device.Insert'
Jan 18 07:02:35 pureos usbguard-daemon[646]: uid=0 pid=606 result='SUCCESS' device.system_name='/devices/platform/soc@0/38100000.usb/xhci-hcd.5.auto/usb3/3-1' target.new='allow' device.rule='block id 058f:6387 serial "A430786F" name "Mass Storage" hash "B+FqwLiWZRK/MDEKyQ6xbqPK5mG4GgVYyTlEI861WIk=" parent-hash "U1nFyrkh8NpSDAU6gmicq7SQ13ff+o3bmO/lcp19jvA=" via-port "3-1" with-interface 08:06:50 with-connect-type "unknown"' target.old='block' type='Policy.Device.Update'
Jan 18 07:02:35 pureos mtp-probe: checking bus 3, device 2: "/sys/devices/platform/soc@0/38100000.usb/xhci-hcd.5.auto/usb3/3-1"
Jan 18 07:02:35 pureos mtp-probe: bus: 3, device: 2 was not an MTP device
Jan 18 07:02:38 pureos kernel: [ 172.437224] scsi 1:0:0:0: Direct-Access Generic Flash Disk 8.01 PQ: 0 ANSI: 6
Jan 18 07:02:38 pureos kernel: [ 172.441107] sd 1:0:0:0: [sdb] 245760000 512-byte logical blocks: (126 GB/117 GiB)
Jan 18 07:02:38 pureos kernel: [ 172.441329] sd 1:0:0:0: [sdb] Write Protect is off
Jan 18 07:02:38 pureos kernel: [ 172.441338] sd 1:0:0:0: [sdb] Mode Sense: 23 00 00 00
Jan 18 07:02:38 pureos kernel: [ 172.441536] sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
Jan 18 07:02:38 pureos kernel: [ 172.448107] sdb: sdb1
Jan 18 07:02:38 pureos kernel: [ 172.448509] sd 1:0:0:0: [sdb] Attached SCSI removable disk
Jan 18 07:02:39 pureos dbus-daemon[741]: [session uid=1000 pid=741] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.4' (uid=1000 pid=738 comm="/usr/libexec/tracker-miner-fs ")
Jan 18 07:02:39 pureos udisksd[595]: Mounted /dev/sdb1 at /media/purism/3E27-549E on behalf of uid 1000
Jan 18 07:02:39 pureos systemd[697]: Starting Tracker metadata database store and lookup manager...
Jan 18 07:02:39 pureos dbus-daemon[741]: [session uid=1000 pid=741] Successfully activated service 'org.freedesktop.Tracker1'
Jan 18 07:02:39 pureos systemd[697]: Started Tracker metadata database store and lookup manager.
Jan 18 07:03:13 pureos tracker-store[2160]: OK
Jan 18 07:03:13 pureos systemd[697]: tracker-store.service: Succeeded.
Jan 18 07:03:13 pureos systemd[697]: tracker-store.service: Consumed 3.508s CPU time.
