When I connect my L5 to my beloved FreeBSD laptop with an USB-C cable, on both ends exists (L5: usb0) or come up (FreeBSD: ue0) a network interface:
ifconfig usb0
usb0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 96:06:ad:58:63:9d txqueuelen 1000 (Ethernet)
RX packets 448488 bytes 31739673 (30.2 MiB)
RX errors 6 dropped 0 overruns 0 frame 0
TX packets 306592 bytes 3677180864 (3.4 GiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
ifconfig ue0
ue0: flags=1008843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST,LOWER_UP> metric 0 mtu 1500
options=80000<LINKSTATE>
ether 3e:07:40:6d:13:91
inet6 fe80::3c07:40ff:fe6d:1391%ue0 prefixlen 64 scopeid 0x3
media: Ethernet autoselect
status: active
nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL>
but nothing else happens in the sense of DHCP; a dhcpclient is started on FreeBSD for this interface ue0.
I can use ifconfig ue0 10.0.1.1 on FreeBSD and on the L5 ifconfig 10.0.1.2 and can run fine ssh purism@10.0.1.2 from FreeBSD to the L5.
What could I do that the L5 gives an IP addr to usb0 and respends to the dhclient listening in FreeBSD on ue0?
UPDATE:
When I do the same USB-C connection using my MacBook Pro, IP addresses get assigned automatically as:
purism@pureos:~$ ifconfig usb0
inet 192.168.33.2 netmask 255.255.255.0 broadcast 192.168.33.255
inet6 fe80::4d93:bdb7:ac4b:698 prefixlen 64 scopeid 0x20<link>
RX packets 1799784 bytes 111111162 (105.9 MiB)
RX errors 18 dropped 0 overruns 0 frame 0
TX packets 548389 bytes 7352130824 (6.8 GiB)
~ apitzm$ ifconfig en7
en7: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=404<VLAN_MTU,CHANNEL_IO>
inet6 fe80::18de:caef:aa2d:3bd6%en7 prefixlen 64 secured scopeid 0x13
inet 192.168.33.1 netmask 0xffffff00 broadcast 192.168.33.255
nd6 options=201<PERFORMNUD,DAD>
media: autoselect (100baseTX <full-duplex>)
status: active
This is because in the MacOS some DHCP services is started with
#!/bin/sh
# start the DHCP server in MacOS
# see also:
# https://www.swissns.ch/site/2014/05/running-mac-os-xs-built-in-dhcp-server/
# config file: /etc/bootpd.plist
# guru@unixarea.de, March 2023
# start:
sudo /bin/launchctl load -w /System/Library/LaunchDaemons/bootps.plist
UPDATE 2:
In the past I did the same with an Ubuntu mobile phone (BQ E4.5), see my booklet here:
The phone have had the IP add 10.42.0.1 which means that DHCP was provided from the phone to the FreeBSD laptop.
