Use Appimage on librem5
is anyone able to use Appimages on Librem 5 [evergreen]
For instance, Singlebox is an appimage available for linux as well. Works on my linux mint laptop. It integrates [sandbox] various apps. Quite easy to use and handy to consolidate even popular apps within one single App
You need to make sure that the image was compiled for the ARM64 CPU architecture. If your laptop has an Intel CPU, the same file will not work.
I did download the arm64 image file. I did the check with uname -m on my phone.
And it is not about the laptop. but installation on L5
And did change the authorization of the file to executable.
Just run it by console then you will see what is going on.
Cant find any package via expansion [ globe]
any idea?
