Useful tool to help clear up space
I’m not sure if anyone has used this utility before but I didn’t know about it. It’s a CLI based file explorer that really helps to drill down and find where you can clear up space on your linux device. It’s called “ncdu”. sudo apt install ncdu will install it.
I use this GUI tool to help clear space on the L5.
The only tool I use for cleaning up space is from Purism:
Stacer on the L5?
I will look at it
Yes, it works, although its fit onto the L5 screen is not perfect.
The compositor settings set on the L5 to reduce size I take it?
The compositor doesn’t have any effect on Spacer’s appearance, but Spacer is still functional, for me.
I’ve used stacer as well but I just prefer this CLI tool. It’s quick and fast to find wasted space.
