The only issue with this is that it may have sent off data you don’t want sent off, and just reviewing the logs may be too late. If you don’t mind it grabbing any arbitrary file off your phone, then it doesn’t matter.
One way to work around it is to just have it give you commands to run, which you then paste the the terminal, then feed it the output. This way you know in advance what it wants and the results it gets. It’s way more tedious though.
Have you considered publishing a human-cleaned-up version of your log, that lists what a human could do on a Librem 5 to achieve the same benefits, for example if someone wants the value of your fixes without the potential risk of an agent having access to their device?
No but wouldn’t be a bad idea. I’m trying to post fixes as I solve my punchlist problems with a link to relevant forum thread under the SOLVED text.
This scenario is a bit different than just a list of bash commands I can post. Grok Bot did a lot of Gnome Calls app launches with the debug option enabled to diagnose the problem. Then it used that diagnostic info to recompile the Gnome Calls app with several patches and backports included. I made that package and the fix summary info available here.
