I was driving somewhere I don’t normally drive and I noticed that my phone said it was using Verizon Service. I was able to call, receive texts, and use data.
I’m not sure what this says about anything, but I thought I should mention it.
It sounds like your device was roaming into Verizon’s cellular network and reflected the change while within it.
Did you previously set the modem to have a long wait between attempts of sleeping?
I think that I might have, yeah
Double-check which method, one method requires mnaual refreshing (depending on the ms timeout).
