Can I make video calls on telegram or matrix?
I’m using Telegram-desktop flatpak app, I can make a call and see other person but my camera is not working.
And I’m yet to find app for matrix
The Dino app.
Dino only supports XMPP / Jabber, isn’t that correct?
The L5’s internal cameras work with Dino video calling?
Right cameras worked on the Pinephone used to test. There is talk of this coming to the Librem 5, but as of right now, video calling through Dino do not work. Audio does, and you will see the video of the other person, but you will not broadcast any video.
The hardware between the Pinephone and the Librem 5 is VERY different. Assumptions of things working because they work on the other is folly at best.
Actually can I connect USB webcam and expect it to work?
yes, that works.
let me try that (maybe in a day or so)
[EDIT] : works out of the box for Telegram.
I may try compiling Fluffychat or give Nheko a try again
