VNC remote control Your Librem form your desktop system
When I was running a pinephone I wrote this guide, edited for purism which I just got it working on!
Do you wish there was an easy hands-free way to interact with your phone’s touch GUI while sitting in front of your desktop system?
Would you like to compose, read, and send SMSs and IMs using your full size keyboard? Interact with your mobile apps using your desktop’s mouse, and screen?
Is there a way to cut and paste between your phone and Desktop?
Maybe you would like to initiate and end hands-free or speakerphone calls without touching your phone?
These and more are all possible using VNC to remotely interact with the GUI of your phone.
Let’s start with your phone; mine is running PureOS but the instructions should work for other distros; use your system’s package installer. (this is for systems running Weyland for video, x11(and mir/surfaceflinger) uses a different VNC server) For the last few years this has been partly broken on my old Pinephone & PPpro, I saw a grey VNC screen but I could just look at the phone to work and mouse, keyboard, and cut/paste worked fine, pureOS crimson everything works great!
Code:
sudo apt install wayvnc
once wayvnc is installed the way I run it is with a launch script I keep in my home directory, I named my script V (the 0.0.0.0 allows incoming connections from outside localhost)
Code:
#! /bin/bash
wayvnc 0.0.0.0
make our script V executable
Code:
chmod +x V
launch manually on the phone’s shell console like this
Code:
./V
The VNC server on your phone is now waiting for a client to connect, as configured is not secured and is unencrypted.
This setup when run on your Weyland video server phone will let your login when the VNC server is running on your PP without any security or password config on either side. The VNC server script above is launched and killed manually so it is not running all of the time in this config, you save precious battery when mobile. If you wanted you could make a desktop entry to give you a GUI launcher for the sell script, just kill that shell window to kill the server.
Now install the VNC viewer GUI on your desktop Linux machine(other OSs also have VNC client software)
Code:
sudo apt install tigervnc-viewer
Now in this insecure home LAN setup just run ./V on your phone, then set the phone’s LAN IP address in the tigervnc-viewer GUI running on your desktop system and click connect; a window with your PP’s interactive GUI will appear on your desktop machine.
In options I recommend reviewing the cut/paste options in tigervnc-viewer Input tab, clicking the ‘show dot when no cursor’ in the also in Input tab so you have a way to see your mouse in some server configs, as well as ensuring that in the Security tab the encryption and authentication options including none as in my example are to your preference.
This is all you need to remote control your phone via desktop; it is a near perfect way to interact with your Weyland phone. This setup also works if you are using the phone as your wifi(or USB cable or Bluetooth) tether hotspot just be sure to update the phone’s IP address. This quick tryout setup is only viable in a situation where the phone and laptop are on a private WLAN with no possibility of other users, any other situation where the VNC server is running gives all users who can scan the network for open VNC port free GUI access to your pinephone or librem with no barriers. It is easy to set a user name and password as well as encryption for the connection, a secure setup requires editing a .conf file on your phone with username and password as well as generating an RSA key. see https://github.com/any1/wayvnc
If you have trouble with cut/paste showing boxes rather than text it is a font matching problem and I have solved this by using the on-phone web browser for some non-English languages rather than my desktop’s; there are better ways to solve the problem though.
VIew the wayvnc git for secure setup and running instructions https://github.com/any1/wayvnc
I find that if I am doing heavy interaction with my phone while in my office VNC, an SSH session, as well as Filezilla to move files around makes everything so easy I rarely need to touch my charging PP except to wake it up if it goes into standby mode and disconnects from the WLAN.
There seems to be a typo. I believe
sudo apt instal tigervnc-viewer
should instead be
This does indeed leave me wondering if it would be smarter to put a broadmobi and sim into a Librem 14 than to bother with a Librem 5. Is that a hot take?
Librem 14 looks like a nice machine but I like having only a phone, sometimes a tablet too when I need to go out and only bring my desktop-replacement lappy with a big GPU when required.
Thanks for the error check, fixed it!
\What I did:
Blockquote
[sudo] password for purism:
Reading package lists… Done
Building dependency tree… Done
[E:] Unable to locate package wayvnc
“E:” drive? Never used E: drive except a long time ago to set a new card (size is min
64g. Free 57g).
How kewl is that.
I don’t remember what I did, but don’t care much if L5 lives or dies, I unplugged power cable from L5, and was able to make a USB cable to plug in to L5 and then I plugged other end to a USB port. Using Win file explorer I opened the Picture folder and copied all images to Win 11 machine. Do you remember how I did that :zany_face:?
~f
sorry, this guide is for Linux users in particular using the apt package manager native to Debian based distros. There are VNC programs for windows too but I am not very windows literate so I would rather not lead you to a suboptimal solution. once you have the wayvnc installed on your Librem phone and start it up as described you can point the windows VNC program at the running VNC on the Librem.
