Thanks for putting that together. Lots of useful info.
There were a few things in the section on SIP that were a bit opaque to me e.g.
- Alice calls bob@baumeister.com but somehow it shows the call as To: bob@builders.com - I can believe that various pieces of software might map a destination, but I have my doubts that translating from German to English would be part of that.
- In the SDP message, where does the IP address of 197.51.100.1 come from?
In the section on RTP, it looks like the formatting and link for āopusā are broken. Maybe a markup issue.
For fun I tried
gst-launch-1.0 -v audiotestsrc ! alsasink
I just wanted to know what the test source produced.
Itās a bit loud. So now I am wondering whether there is a pipeline element that can reduce the volume.
Itās very easy to discover all the available gstreamer elements with āgst-inspect-1.0ā. I just did āgst-inspect-1.0 | grep volumeā and found that thereās an element called āvolumeā. Then to know the settings that element allows, do āgst-inspect-1.0 volumeā and you can see that thereās a property called āvolumeā which is a float where 0.0 is 0% and 1.0 is 100%.
So with that in mind, the following pipeline works to set the volume to 20%
gst-launch-1.0 -v audiotestsrc ! volume volume=0.2 ! alsasink
