Anyone know how to pull the wallpaper on L5-v2-header image above?
Not all image can be used in Locker-Screen but this one look good, still missing some contrast on top-bar-right but is OK.
You mean that brown and gold screen in your first screenshot? It’s probably just a mockup, but I’m sure you could create something very similar yourself.
Edit: @carlosgonz Actually there is a similar wallpaper in Appearance in the L5 settings. In the file system, it’s located here: /usr/share/backgrounds/gnome
@irvinewade , could we have a separate category or tag in this Discourse instance specifically for Librem 5 v2 to collect all the posts about it and distibguish them from the original Librem 5?
Probably having a single category for both is fine.
Hardware > Librem 5
But having a single tag for both is not enough.
librem-5
Edit: The new tag is now available: librem-5-v2
Yes the brown-and-gold image. The image loook very interesting… it ship many features.
I do not think i may create a clone to looks same on my L5.
Thanks i will check.
I can not create new tag. @janvlug can do it.
No, als also cannot.
Are you sure you can’t? If you click on the pencil icon next to your title, and then click in “Optional Tags,” it doesn’t let you add e.g. “librem-5 v2” and then save it?
New tag it can not save it, the box is just to search a existing tag.
I guess @Pirate_Praveen blocked this option.
That worked. How you did?
Me, too: Tag created for Librem 5 v2 topics
