Waydroid recommendation
@irvinewade
do you recommend waydroid? Or is it still buggy?
I recommend containing your Android use cases in a separate, dedicated device for it.
from Pure OS store?
Instructions for installing Waydroid on the Librem 5:
Here is same. Waydroid it is not Security and evenworse is Overload the L5. So the best will as @FranklyFlawless suggested:
Yeah I can order on stuff like that. Thanks for all the info.
I try hard to avoid running any Android application even if it makes life harder. When I don’t have a choice (second authentication factors for banking and work, basically), my preferred option is Waydroid which works ok. I run it on my Librem5, which means it has no access to my data (contact list, calendars and photos, mainly) or location. I know a dedicated attacker could probably escape Waydroid and access all that but don’t consider that a realistic threat. If you’re willing to spend (recurrent) cash, someone posted instructions on how to run it at a hosting provider (which would then, in theory, have access to your in-waydroid data but presumably not your personal data/location at all).
Third and IMO worst option is having a hardware Android device, especially worst if you need that on the road. I use a Fairphone for the two applications that I must use and that require a camera for scanning codes. So when I take it along I’m sure The Man is still keeping track of where I go.
(Honestly, I’m still traumatised from that time when my Android phone (specifically, Google Maps) suddenly asked me questions about a restaurant where I had eaten a week earlier, as I was again walking on the street near that restaurant. I had not opened Google Maps at any time, but it was still clearly keeping track the whole time)
You can use a Faraday sleeve to block wireless signals:
