Within the software application I can only download “firewall” & “firewall builder”
What is the default installed firewall manager within the OS? Is there even one? if so what are the rules by default? deny all incoming / allow all outgoing?
Interesting enough I looked through “apt list --installed”… nftables is no where to be found. it is NOT the default firewall. I did however find iptables within the list.
Is there a difference in kernel and OS versions between PureOS as a linux distro for normal desktop/laptop use (Byzantium) vs what the Librem5 phone uses? I’m specifically talking about Byzantium which is the .iso available for download for PC use.
unfortunately according to the list-rules command iptables by default doest not look like it deny’s any incoming traffic:
$ sudo iptables --list-rules
-P INPUT ACCEPT
-P FORWARD ACCEPT
-P OUTPUT ACCEPT
What gui do you guys recommend for IPtables? I have to research CLI commands to change these rules as the --help is a little to vague for me to know how to set it up as a simple firewall
That is interesting - the possibility didn’t occur to me. I’m running at the moment L5 with non standard byzantium and have nftables and iptables controling the firewall. It may be that original byz is iptables and the updates have been pushed at some point. Checking pureos.net may tell more (it lists packages at Repositories & Suites - PureOS Software). There may be differences, but as I haven’t used other devices with it, I’m not sure.
As for the iptables GUI, I remember using some fork of Firestarter with it (it’s been a while). But as you mentioned GUFW before, if that’s more familiar to you, over all it might be a route to follow.
[These two threads should be merged https://forums.puri.sm/t/ufw-gufw-not-working-correctly]
Yeah… it makes me a little worried that there are some not obvious differences between their flagship Librem Pure OS and their normal PC Pure OS. I’m worndering how active updates (security and otherwise) get pushed to it if they aren’t even keeping the firewall management the same.
I ended up installing GUFW again without UFW, just using it to manage IP tables and it configured it with a simple toggle.
The only issue now is that GUFW will not hold an ACTIVE toggle for the firewall past a reboot or shutdown. This leads me to believe that even if I went through the more complex IPtables setup through the terminal, that none of the changes will be held past reboot or shutdown.
I’m wondering if the PC iso of byzantium is even configurable in this state for network security. Is there a way to ping this thread to devs?
Its almost acting like an immutable distro (any changes to my firewall are reset to original settings after any reboot or shutdown)
So I was unaware if there was a firewall preinstalled with PureOS (Byzantium). Is there? I couldn’t find one, so I installed UFW and GUFW.
They both work when opened and activated (ie enabling ufw via terminal or opening gufw and clicking to activate the firewall).
The problem is that they wont stay active after a log out or reboot. It’s like UFW wont save any status updates coded to it though CLI nor through the GUI.
This causes issues when rebooting/powering up as there is no internet access UNTIL ufw is either activated through terminal or gufw.
I uninstalled the apps and all is working well, but I want to put a decent firewall up as a bare minimum and the only firewalls listed in the software store is fwbuilder (firewall builder) or firewall (firewall configuration).
This is why I just installed UFW since it was an easier setup. But not really sure if the two listed apps in the software store are really worth downloading and using. I read in a past post that IPtables might be preinstalled and used as the firewall, but i’m unsure how it is configured out of the box.
You’ll get good info on setting up persistent firewall with from those links, which ever you choose to use. For understanding nftables and firewalling, this article with process diagrams may help too. Debian wiki does suggest not directly editing nftables (ref) and to use firewalld [as opposed to GUFW, which is not intended as an appropriate example for nft GUI], although it may not work with L5 screen, if that’s what you are using.
As for the defaults, I’m not sure, as I don’t have them left anymore (all kinds of edits over the years). Check to see yours with sudo nft list tables and then sudo nft list table <name of table, like ip nat>.
Also, there are some notes in the old threads, like this: Firewall and Librem 5 and Not recommended to use a firewall? - #16 by Kyle_Rankin and:
The behavior maybe related to rules preventing iptables and ufw conflicting, take a look at: Can UFW work with iptables-persistent? - Unix & Linux Stack Exchange and Possible conflict between ufw and iptables-persistent · Issue #414 · pivpn/pivpn · GitHub
Geez, what a major miss from PureOS. Thanks for the firewall JR, definitely useful information. I used the
Blockquote
sudo apt-get install gufw
Blockquote
that you suggested. As I am not great with programming yet I’ll just check to make sure it is turned to deny for incoming and allow for outgoing when I reboot my phone each time. Too bad I can’t use the alarm app to remind me unless I reboot at a specific time every single day.
Glad to have some security in place, not sure how good it is but it is a start. I’ll read your guides and blog posts after work. Thank you
Gotta retrain that blockquote use.
Markdown:
The Markdown for the code should look like this:
When using blockquotes, change the text:
Blockquote → Content
Alternative Markdown for blockquotes:
[quote]
Blockquote -> Content
[/quote]
While every customer should be able to find out what firewall, if any, is installed by default, and, if so, what the default firewall configuration is, there are other considerations.
So, yes, given Purism’s emphasis on “the power of defaults” the default firewall situation should be clarified and improved, but a firewall is not the end of the story and is not set-and-forget.
As such therefore it definitely matters what kind of device we are talking about e.g. Mini v. laptop v. phone.
