Where to look for the software and packages that come in PureOS?
I am looking for a lot of software that I use and I need to know if they are in PureOS. And I don’t want to install the entire system just to see whats in it!
I looked at PureOS on DistroWatch, but that did not tell me everything that’s in the distro I don’t think, right?
You could create a Live USB, boot into it, and then check the available packages from the live installation, so that you aren’t fully installing PureOS.
Caveat: many applications are moving to the Flatpak format, which PureOS supports, but which would not show up in that list. For Flatpaks, the main source is Flathub
