After reboot
I would have liked to see the full text. Go to the menu (top right) and click on “zoom -”
Have you done chmod +x ~/Documents/2.sh to make the script executable, otherwise, you need to have ExecStart=/usr/bin/bash /home/purism/Documents/2.sh in the service file. (restart the service after modification).
PS: I have edited my original post to do the changes through one or two scripts. I hope it is clearer for all now after the replies.
That screenshot is rotated for me. Difficult to read!
2.sh needs to start with a line #! /shell where /shell means a path to a valid shell e.g. /bin/bash Does it?
Well seen!. It is also why i converted my instructions in my original post, to avoid typing mistakes.
@irvinewade @Lionel Really thank you so much for your lasts posts!! It’s working perfectly now!! Just last question to understand: why I see Lionel’s zram swap13.3GB in the first post? I just have 5.3 that’s ok for me! But how to reach that number? I also tried setting zram-fraction=4 but it remained 5.3! Maybe it dinamically increase to 13.3 when zram reach 5.3?
Anyway zram-fraction is set on 2, now, as suggested! And L5 temperatures are ok now!
Thank you
Great !
13.3 GB with fraction = 4.5 (It is all explained in my original post). It was just a test for me to see if it did a problem (freeze or crash) with all apss opened.
I estimate it not useful to have zram above 5.5 GB, but make it if you think you need it.
Do you really see a difference with temperature?? I was not sure about my feeling and as i remember, i did some of the tests on the floor which was then cooling the phone.
Yes! I opened all apps installed, including Waydroid and all temperatures were below 50 degrees (around 47/48). Before zram, as explained in another thread, my L5 reached 60 degrees!!! It was so hot that I had problem to keep it in my hand!
Great to confirm my experience! Thank you for your perseverance in trying this trick.
I saw mention of PR for this. Anyone have an idea when it might get into “production”?
Trying to decide if I should try it now or just wait (uncertain whether it would conflict with doing it manually ahead of time in some way).
Just wanted to say thanks, this did miracle on my librem5
What do I do for the path portions?
also, journal error ocurred for restart systemd-zram-setup@zram0
Couldn’t restart service, but after reboot, my setup was set properly. 6.1G of ZRAM
You have to do the changes just after booting, because if the zram gets used too much from the system it blocks the service’s restart.
tried this on pmos for my librem 5 because pureos mobile data handoff bug still exists. I have to follow the link beblow since there is no systemd. Is this a correct way to extend zram by editing zram.init?
Can there be any issue if i have already extended the swap file to 3.5 gb and also extend zram ?
I don’t think so. I did many different tries with different config before I write this post.
