I don’t know. I find my solution better (1.5G is not enough)
But isn’t your solution to compress all data, which means more CPU usage and therefor more battery drain? I mean sure, if you need it, it’s better to you. But for people who can live with less RAM it’s a bad choice - theoretically (I did not test if it makes a real difference).
I’ve been using your solution quite successfully and actually noticed less CPU usage.
Thanks for your report. This was also my feeling but i have not really verified it. Just the stability was a great improvement.
Once they have some sort of way to put processes in the background then I would say the power consumption would drop even more combined with this hack.
I am having trouble making ZRAM persistent, I receive this error code after entering:
sudo systemctl restart systemd-zram-setup@zram0
Job for systemd-zram-setup@zram0.service failed because the control process exited with error code.
See “systemctl status systemd-zram-setup@zram0.service” and “journalctl -xe” for details.
I tried
journalctl -xe
and I received this:
lines 1987-2022/2022 (END)
Jul 24 12:13:37 pureos avahi-daemon[572]: Registering new address record for fe80::33d2:b7c6:81af:a62c on usb0..
Jul 24 12:13:38 pureos NetworkManager[584]: [1721841218.1732] device (usb0): carrier: link connected
Jul 24 12:13:38 pureos login[4723]: pam_unix(login:auth): check pass; user unknown
Jul 24 12:13:38 pureos login[4723]: pam_unix(login:auth): authentication failure; logname=LOGIN uid=0 euid=0 tty=/dev/ttyGS0 ruser= rhost=
Jul 24 12:13:39 pureos systemd-networkd[460]: usb0: Gained IPv6LL
Jul 24 12:13:42 pureos login[4723]: FAILED LOGIN (1) on ‘/dev/ttyGS0’ FOR ‘UNKNOWN’, Authentication failure
Jul 24 12:13:45 pureos login[4723]: pam_unix(login:auth): check pass; user unknown
Jul 24 12:13:45 pureos login[4723]: pam_unix(login:auth): authentication failure; logname=LOGIN uid=0 euid=0 tty=/dev/ttyGS0 ruser= rhost=
Jul 24 12:13:48 pureos login[4723]: FAILED LOGIN (2) on ‘/dev/ttyGS0’ FOR ‘UNKNOWN’, Authentication failure
Jul 24 12:13:54 pureos login[4723]: pam_unix(login:auth): check pass; user unknown
Jul 24 12:13:56 pureos login[4723]: FAILED LOGIN (3) on ‘/dev/ttyGS0’ FOR ‘UNKNOWN’, Authentication failure
Jul 24 12:14:01 pureos kernel: edt_ft5x06 2-0038: Unable to fetch data, error: -6
Jul 24 12:14:01 pureos gsd-xsettings[1084]: Failed to get current UI legacy scaling factor
Jul 24 12:14:01 pureos gsd-color[1082]: unable to get EDID for xrandr-DSI-1: unable to get EDID for output
Jul 24 12:14:22 pureos NetworkManager[584]: [1721841262.7474] dhcp4 (usb0): request timed out
Jul 24 12:14:22 pureos NetworkManager[584]: [1721841262.7476] dhcp4 (usb0): state changed unknown → timeout
Jul 24 12:14:22 pureos NetworkManager[584]: [1721841262.7479] device (usb0): state change: ip-config → failed (reason ‘ip-config-unavailable’, sys-iface-state: ‘managed’)
Jul 24 12:14:22 pureos NetworkManager[584]: [1721841262.7538] device (usb0): Activation: failed for connection ‘Wired connection 1’
Jul 24 12:14:22 pureos NetworkManager[584]: [1721841262.7555] device (usb0): state change: failed → disconnected (reason ‘none’, sys-iface-state: ‘managed’)
Jul 24 12:14:22 pureos avahi-daemon[572]: Withdrawing address record for fe80::33d2:b7c6:81af:a62c on usb0.
Jul 24 12:14:22 pureos avahi-daemon[572]: Leaving mDNS multicast group on interface usb0.IPv6 with address fe80::33d2:b7c6:81af:a62c.
Jul 24 12:14:22 pureos avahi-daemon[572]: Interface usb0.IPv6 no longer relevant for mDNS.
Jul 24 12:14:22 pureos NetworkManager[584]: [1721841262.7868] dhcp4 (usb0): canceled DHCP transaction
Jul 24 12:14:22 pureos NetworkManager[584]: [1721841262.7870] dhcp4 (usb0): state changed timeout → terminated
Jul 24 12:14:22 pureos NetworkManager[584]: [1721841262.7919] policy: auto-activating connection ‘Wired connection 1’ (213909bf-9dc1-30aa-b4b1-6a59da98be79)
Jul 24 12:14:22 pureos NetworkManager[584]: [1721841262.7956] device (usb0): Activation: starting connection ‘Wired connection 1’ (213909bf-9dc1-30aa-b4b1-6a59da98be79)
Jul 24 12:14:22 pureos NetworkManager[584]: [1721841262.8247] device (usb0): state change: disconnected → prepare (reason ‘none’, sys-iface-state: ‘managed’)
Jul 24 12:14:22 pureos NetworkManager[584]: [1721841262.8265] device (usb0): state change: prepare → config (reason ‘none’, sys-iface-state: ‘managed’)
Jul 24 12:14:22 pureos NetworkManager[584]: [1721841262.8293] device (usb0): state change: config → ip-config (reason ‘none’, sys-iface-state: ‘managed’)
Jul 24 12:14:22 pureos NetworkManager[584]: [1721841262.8313] dhcp4 (usb0): activation: beginning transaction (timeout in 45 seconds)
Jul 24 12:14:22 pureos avahi-daemon[572]: Joining mDNS multicast group on interface usb0.IPv6 with address fe80::33d2:b7c6:81af:a62c.
Jul 24 12:14:22 pureos avahi-daemon[572]: New relevant interface usb0.IPv6 for mDNS.
Jul 24 12:14:22 pureos avahi-daemon[572]: Registering new address record for fe80::33d2:b7c6:81af:a62c on usb0..
Jul 24 12:14:22 pureos rygel[4181]: Error creating GUPnP context: Failed to bind socketError binding to address [fe80::33d2:b7c6:81af:a62c%2]:1900: Cannot assign requested address
Jul 24 12:14:24 pureos systemd-networkd[460]: usb0: Gained IPv6LL
Can you parse this and maybe help with what I can try to fix?
The output for the restart was also for me because of this:
- an error in the config file
or - I just needed to restart and make the change again immediately, because if the zram is too used (filled) by the opened apps, the restart service always failed.
PS: In order to make the thread clearer, please delete your log (too long and no trace aboutt zram service).
Next time, you can do better with:
sudo journalctl --since "5 minutes ago" | grep zram
If anything, what Kyle described is easier. zramswap (from zram-tools) is a script that takes the nitty-gritty away. But if you look at /usr/sbin/zramswap, it invokes all the same commands.
Maybe use the other suggestion? systemctl status -l systemd-zram-setup@zram0.service.
Show us your /usr/lib/systemd/zram-generator.conf.d/librem5.conf please.
Maybe, kill some running apps.and restart service again…
Do you have any autostarting apps?
I have not tried the procedure from the original post. Instead, I added the following configuration file and rebooted. I would suggest it instead. The documentation is available in man zram-generator.conf.
$ cat /etc/systemd/zram-generator.conf.d/librem5.conf
[zram0]
zram-fraction = 2
max-zram-size = none
That configuration file overrides the configuration file with the same name, which is provided by Purism.
$ cat /usr/lib/systemd/zram-generator.conf.d/librem5.conf
[zram0]
So, this combines the following advice.
[zram0]
Thank you ![]()
Please I’m trying to do that. What means it?
I’ve to create a second file and save it, like this one, in my microsd?
Thank you
I do not know. However, the following bit of the log seems to indicate that /dev/zram0 is busy by some other process when zram-generator tries to configure it.
I do not know how to investigate it. But I found the following suggestion:
As far as I know Debian has two packages that makes configuring swap on a zram device fairly easy.
They are “zram-tools” and “systemd-zram-generator”.
You should probably check that you have only one installed.
I only have systemd-zram-generator installed of the two.
Only do this (don’t follow any other procedure, i cannot help you), or Why and how to extend ZRAM on L5. A revolution for Librem 5 stability! - #34 by riabenko (may be a better procedure):
I did on my 3 librem 5:
1.Reboot
2.Close immediately any running app because of autostart (or better: remove them from the folder temporarily).
3. And immediately in terminal copy past this in terminal:
sudo tee /usr/lib/systemd/zram-generator.conf.d/librem5.conf <<EOF
[zram0]
zram-fraction = 2
EOF
That means any path of a script like /home/purism/myscrip.sh, that contains the commands you want to run at boot. has to be replaced by the text you want at this place.
For our purpose, the script /home/purism/myscrip.sh should contain:
#!/bin/sh
sudo swapoff /dev/zram0
sudo zramctl --reset /dev/zram0
sudo zramctl --find --size 5G
#/dev/zram0
sudo mkswap /dev/zram0
sudo swapon /dev/zram0
