Running sudo apt upgrade always leaves fwupd not updated. Do I need to upgradde this and if so how? Librem 14.
You can use sudo apt full-upgrade if you want to update it. Full-upgrade will install new software, upgrade will not. Fwupd probably has some new or changed dependencies.
Thanks. That did it.
