Wi-fi working, Bluetooth not working
Librem 13v4
Ubuntu 24LTS
The Bluetooth just stopped working - but the WiFi still works.
rfkill
ID TYPE DEVICE      SOFT      HARD
 0 wlan phy0   unblocked unblocked
○ bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: enabled)
     Active: inactive (dead)
       Docs: man:bluetoothd(8)
Sep 30 11:39:49  systemd[1]: bluetooth.service - Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
/etc/bluetooth$ hciconfig
host@hostLibrem-13-v4:/etc/bluetooth$ sudo dmesg | grep -i bluetooth
[  123.392750] Bluetooth: Core ver 2.22
[  123.392778] NET: Registered PF_BLUETOOTH protocol family
[  123.392779] Bluetooth: HCI device and connection manager initialized
[  123.392783] Bluetooth: HCI socket layer initialized
[  123.392785] Bluetooth: L2CAP socket layer initialized
[  123.392789] Bluetooth: SCO socket layer initialized
sherab@sherab-Librem-13-v4:/etc/bluetooth$
lsmod | grep btusb
btusb                  77824  0
btrtl                  32768  1 btusb
btintel                57344  1 btusb
btbcm                  24576  1 btusb
btmtk                  12288  1 btusb
bluetooth            1028096  5 btrtl,btmtk,btintel,btbcm,btusb
Any advice?
ls -l /sys/class/bluetooth
Might be good to test it in a Live Boot of Ubuntu 24.04 LTS too.
/etc/bluetooth$ ls -l /sys/class/bluetooth
total 0
I’ll try the live usb later the day
Thank you
OK, that would appear to explain why the bluetooth service is not running but obviously only leads to the next question … Anyway,
What Bluetooth card do you have? Does it require firmware? If so, is the firmware file present? Being loaded?
Have you recently upgraded to Ubuntu 24.04 LTS? If so, did Bluetooth stop working coinciding with that upgrade?
FWIW, I have a computer that is running Ubuntu 24.04 LTS and which has Bluetooth hardware and
/sys/class/bluetooth is non-empty and the bluetooth service is running however
  • that isn’t a Librem 13,
  • it almost certainly has different Bluetooth hardware as compared with your laptop, and
  • I don’t routinely use Bluetooth on that computer so I don’t know off the top of my head whether Bluetooth is actually working on that computer.
All of yesterday’s switching device off and on(numerous times)didn’t work.
This morning after proof of concept with Debian live usb - Bluetooth worked fine - Re booted to the Ubuntu and it suddenly worked again.
Strange.
Thank you
