Anyone know if the Wickr messaging app works on PureOS? It lists linux, in general, but not sure if PureOS is included. Might be a good alternate messenger, solution, if needed, for both the L5 and laptops.
Looks like they only offer an installation via snap
, which you can do on PureOS if you want to. See the post here for snap
installation on PureOS.
I haven’t installed Wickr myself since I don’t use it. Wire and Signal, potential alternatives, both run really smoothly on my laptop with PureOS. I added their respective Debian sources, installation and updating is very smooth like the rest of the system.
Note: This is all for Laptop hardware, no idea about L5.
Thanks, I use Signal and Wickr on my spyphone now, so curious as to what will work and not when I get my L14.
Pretty sure you can get Wickr to work if you’re willing to install the snap
store. Too bad they don’t put out an app image. Is there a browser interface for wickr? If so it is easy to create a web app on the librem using Gnome Web
