WiFi Disconnecting
I have a Librem 13 v2.
If I have the laptop open, eventually the WiFi shuts down for some reason. Like it is going into some kind of power save and stopping it (I’m guessing) because the Internet stops working. I have to switch it to airplane mode and back before it works again.
For the record, it’s not connecting to another WiFi host, or losing an IP or anything. I’m well experienced in troubleshooting network connectivity issues, and this is like the device just goes to sleep in the laptop until I manually reset it. Happens after 15 minutes or so.
Anyone seen this? Know of a solution? I have done the usual of apt update, apt upgrade, etc. So everything is up to date. But so far, no luck.
Kevin
Me too. i have same version as you and thought it was either me messing up the settings or my router.
turns out its neither.
i have to re-boot to get the wifi back up as airplane mode doesn’t do the trick for me.
Anyone got any ideas?
I meaning baring any software issues, it could be that the radio on your wireless card is burning out. Good news it is easy to replace (i believe). Best to contact Purism customer support.
I have a different Librem (v3) but I haven’t seen this. Are there any messages from dmesg? Or in the system log?
Dmseg error gave this
firmware: failed to load i915/skl_dmc_ver1_27.bin (-2)
[ 1.485898] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[ 1.485902] i915 0000:00:02.0: Direct firmware load for i915/skl_dmc_ver1_27.bin failed with error -2
[ 1.485904] i915 0000:00:02.0: Failed to load DMC firmware i915/skl_dmc_ver1_27.bin. Disabling runtime power management.
[ 1.485906] i915 0000:00:02.0: DMC firmware homepage: https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/i915
so i searched through Startpage and got this.
Take it back it didn’t work, Wifi still dropping out.
how do i get to the system log?
Should be in
/var/log/syslog
You can also look in the journal to see if there are any issues;
sudo journalctl
Might be interesting to see what this is saying;
sudo journalctl -t NetworkManager
Also;
sudo journalctl -t wpa_supplicant
gives me
Feb 03 19:00:55 librem NetworkManager[1690]: [1549220455.4889] dhcp6 (wlp1s0): request timed out
and
gives
Feb 02 23:13:26 librem wpa_supplicant[1672]: wlp1s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Feb 02 23:13:26 librem wpa_supplicant[1672]: nl80211: deinit ifname=wlp1s0 disabled_11b_rates=0
Feb 02 23:13:26 librem wpa_supplicant[1672]: wlp1s0: CTRL-EVENT-TERMINATING
anyone got any ideas?
my Wifi is now dropping out every 40 mins.
After digging further, it appears my problem was related to Docker. Docker was putting the WiFi to sleep. Uninstalling it solved the problem. Not sure why, as I don’t have this issue with Docker on other platforms, but at least I know it was not a hardware or driver problem.
Have you opened your computer to check the connections on the Wifi card? While I don’t really think it’s a loose wire issue based on the error log, it might not hurt to check.
I think journalctl -t wpa_supplicant is onto something. That CTRL-EVEN-TERMINATING seems important. Also, why dhcp6? Are you on an IP 6 network? Are you behind a Google router or similar?
Is this all the output that journalctl can produce? Running it on my system produces a number of lines including
-- Logs begin at Wed 2019-02-13 13:49:51 EST, end at Fri 2019-02-15 20:21:26 EST. --
Would you be kind enough to dump all your journalctl output? Also, the syslog might hold some more info, try
sudo grep -i wlp1s0 /var/log/syslog
i assume you want the readout from when the Wifi goes down?
Thanks for the help so far
Sure, whatever output you can get that helps us debug the issue is most welcome. :slight_smile:
thanks for all the help.
i eventually found a forum for Ubuntu that had the same problem and in my case the solution was to remove Wicd Network Manager as it was causing the issue.
I have the same issue running PureOS on a Macbookpro.
Randomly the internet just disconnects. The wifi symbol is still showing. I have plugged in a USB wifi in addition to the built in wifi. This helps some but the internet still disconnects randomly.
To get back on, I have to turn off the network and turn it back on at the top right in the status bar.
Any solutions?
