Wifi/HKS not working
Hi!
I received an Evergreen device yesterday and was able to connect to my wifi network. Over night I disconnected the Wifi using the HKS. I have been trying to get wifi back all day but nothing seems to work. I would appreciate any kind of help.
Btw I tried finding solutions, adjusted time setting, restarted the L5 a bunch of times and read the “known issues” document.
It looks like the HKS simply isn’t working anymore, since both Wifi and BT both cant find their hardware.
Best regards
PS: Evergreen, 5.11
Maybe you have the same issues described here:
Anything in the logs? Boot up with the WiFi/BT HKS in the “off” position, let the flurry of boot activity finish (e.g. wait a few minutes), then switch WiFi/BT “on” and see what appears in the log.
If you reach the point of wanting more avenues (i.e. absolutely nothing in the log in response to turning on WiFi/BT), check that the WiFi/BT M.2 card is seated properly.
:slight_smile: Content free update notes (#26) · Issues · Librem5 / pureos-store · GitLab
