Can you copy and paste the exact command you are entering? You can copy text from the terminal by highlighting and using Shift+Ctrl+C (and you can paste text into the terminal with Shift+Ctrl+V)
i can push the up button to bring back the command and rewrite it
Sorry, I mean, please paste the exact command you are using here in these forums, so that we can have a look. And please tell us where the .deb file you are trying to install is located, as well as the actual name of the .deb file.
i used the exact commands you suggested me
i transfered the files through an usb cable from my phone to the downloads folder of my laptop,yet it says it doesn’t find it there
Until I see a screenshot or something, I don’t think there is much more I can do to help.
You realise that you can’t use the exact command suggested, which was
sudo dpkg -i ~/Downloads/<name of file>.deb
because you have to replace <name of file> with the actual name of the file, leaving out the < and leaving out the >
In fact, in shell the above will fail horribly / make a mess (due to the use of the unintended shell redirection operators).
