I’ve just come back to my Librem 5 after not using it or a long time. It said there was an OS upgrade to PureOS 11, which I accepted and loaded, but now my WiFi and Bluetooth don’t work at all. I don’t know much about the Librem 5 as I haven’t used it much, but I did a “sudo dmesg” and saw this amongst the messages:
r8152 4-1.1:1.0: Direct firmware load for rtl_nic/rtl8153b-2.fw failed with error -2
r8152 4-1.1:1.0: unable to load firmware patch rtl_nic/rtl8153b-2.fw (-2)
which I thought might be related. However, I’ve no idea what to do about it. Can anyone help?
Those messages look like they are about a Realtek USB ethernet dongle or similar (based on “r8152” and “rtl8153b”), I think that’s unrelated to your wifi problem.
Try installing any further updates after the upgrade to PureOS 11, by running “apt update && apt upgrade” in the terminal.
If you check your kernel version using the command uname -a – what does that say?
On my Librem 5 with latest PureOS 11 (Crimson) the uname -a command says this:
purism@pureos:~$ uname -a
Linux pureos 6.12.0-1-librem5 #2 SMP PREEMPT 6.12.100pureos1~cri1 2026-08-01 00:38:00 UTC aarch64 GNU/Linux
If you see something else, then you have another kernel version for some reason.
Oh and also, check that you have not turned wifi off using the kill switch.
If you’ve come back to it after, say, 3 years then your software was probably woefully out of date. Please post output from
lsb_release -c
Choices would be: amber, byzantium or crimson.
Generically speaking, if your WiFi doesn’t function, there may be merit in using the kill switch to kill WiFi, rebooting, letting it finish the boot, giving it a few minutes, then switching WiFi back on. Then you can at least identify messages from switching WiFi on separately from messages from the boot.
Thanks. First - yes, of course you are right about the Realtek device - I should have spotted that.
I was nervous about doing apt update/upgrade. I assumed that the best way to upgrade would be to use Purism’s graphical updater as I wondered if it did any extra stuff on top of apt, that I would miss if I just ran apt directly. However, as you suggested it I tried it, and it updated the kernel (though I did have to uninstall an old kernel to make room first), and it appears to have fixed my WiFi.
I do wonder why the GUI level upgrader that I ran first failed to do all this. I would have expected it to pull in the current kernel, making room for it if necessary, but it seems like it just silently failed to do that and left me with an obsolete kernel.
To be honest, I don’t know. I’ve used the phone very little and it hasn’t been touched for quite a while. I haven’t got into the details of the software so I don’t know the codenames. I bought it in the hope of having a more private phone for daily use but soon realised that the battery life was nowhere near good enough to last a day. I dug it out because I wondered if software updates in the meantime had improved the battery life.
For me, I think the battery usually lasts about 8 hours nowadays. That’s not great, but it’s okay. I usually plug it in to charge at the office where I work, and I keep a powerbank in my bag.
