I just read the Alexandre Oliva mail about the GNU Linux-libre 5.0-gnu release. And I wonder if PureOS kernel version running on Librem 5 will be GNU Linux-libre 5.0-gnu.
In sort, is A Kernel Without Any Binary Blobs/Firmware.
to get the sweet amd open source drivers for apus and dedicated gaming cards you only need the kernel 4.18 from ubuntu 18.10 but pureos has alot of stuff removed or disabled that don’t concern the librem specific hardware. what is so great about the 5.0 other than it’s newer.
I would like the PureOS OS to have Linux-libre as its kernel. Binary blobs are not just removed, remaining obfuscated/proprietary code and proprietary software/firmware would be gone as well.
That would reduce the potential of code exploits and any of its traces.
By the assertions of the wikipedia page, PureOS is using a Linux kernel that only removes all binary blobs. I believe PureOS can use the Linux-libre kernel. Of course, testing is required before implementation. Note that the Uruk GNU/Linux currently uses Linux-libre kernel.
There is no assertion because it doesn’t say “is used by default in only these distributions.” The fact that PureOS isn’t on that list doesn’t mean anything.
