In case someone might be interested in using algo vpn on the Librem 5, I just built the wireguard package which is the preferred vpn client for algo .
In order to get wireguard working, I had to install resolvconf but otherwise it was simply a matter of following the instructions.
@Kyle_Rankin It would be great if wireguard could be a part of the standard Librem 5 packages. Thanks!
dcz
November 27, 2020, 11:12am
2
Wireguard will be available in the Byzantium release of PureOS, because that one is based on Debian Bullseye Buster with the package in place.
Thanks!
Is there a public timeline for when this is expected to happen? No, is a reasonable answer. I am just trying to get myself prepared for the eventual reception of the Librem 5.
dcz
November 27, 2020, 2:56pm
4
I’d give a lot to know that, given that I’m fighting that problem
EDIT: I thought I was replying to the other thread. More info below.
Won’t this be the same time frame as debian bullseye release? Has this been different in the past for PureOS?
dcz
November 27, 2020, 3:37pm
6
I meant to write Buster - both have been out for a while. We do not migrate between Debian releases automatically, so it takes time.
Nevertheless, we’ve been preparing for this for a while, and it should happen within a couple months I think. See this issue: https://source.puri.sm/Librem5/OS-issues/-/issues/169
dos
November 27, 2020, 11:35pm
7
FWIW the Librem 5 kernel has Wireguard support enabled, so indeed it should be just a matter of user-space tooling.
How would one do that?
Thanks.
epinez
November 28, 2020, 1:15am
9
The wireguard-tools package you compiled are the userspace tooling which dos mentioned. They can only work with corresponding kernel support.
Thanks. Unfortunately, the only experience that I have with kernels is making popcorn
epinez
November 28, 2020, 2:19am
11
Yeah but no problem here, dos just wanted to say the Librem 5 kernel already HAS wireguard support built-in!
