The Swedish main company for digital identification has recently changed its security to require NFC when registering a digital ID with their app. This effectively closes the door on running this app in Waydroid, which I was able to do before, unless it is possible to attach a USB NFC reader and make it work in Waydroid.
Try finding a device that works for people with their Linux computers (laptops, desktops - it does not really matter) out of the box, best across distributions and without additional drivers.
That device should then work with the Librem 5, too - worst case, you will need to figure out which extra kernel module needs to be added to the Librem 5 kernel.
Looking at the links, the amazon.es product does not list Linux, while the other one does - I recommend looking for forum threads or product reviews by actual Linux users though.
I would note as well that getting a USB NFC reader working with PureOS might be doable… But the original question mentioned Waydroid and some Android app. That might be a whole different story.
Ok, I bought the Ewent EW1055 NFC reader because it was cheap. It is not recognized in waydroid though, which wasn’t highly expected. Searching the waydroid settings app for nfc returns nothing.
I guess there must be some drivers present. This device states “Suited for Windows and macOS” and “Supports ISO 7816, T=0 or T=1 protocols; complies with PC/SC 1.0/2.0, EMV 4.1 and WHQL”.
I have installed libnfc6 on the Librem5, but I don’t know how to test if the nfc device is actually recognized in byzantium.
Once you find a working solution - if you are able to - then lodge a complaint with the relevant authorities that they are essentially requiring the use of privacy-abusing smartphones to conduct essential daily operations. Then also inform Max Schrems’ organization: NOYB. Maybe he’ll take up the cause.
