No, but I’ll tell you:
1 - from the desktop - click on “Camera (Dev” Camera loads.
2 - Turn 'Torch" on. It’s Yellow light. See the pic I posted #57. If I don’t turn it on, there is no light.
3 - Get very close to target so LEDs light up target (10" - 12" ) Too close and it’s all blurry.
4 - Steady the camera - push the white button @ bottom of screen. There is no knowing if it took a pic; no click, no buzz, no blinking. Check folder. If it’s not there, try again.
5 - done.
I received a reply that said I should push exposure up all the way. The pic in post #57 was taken in the steps above with exposure highest.
CATching up on replies, I set everything up to highest level. Too bright for outside, just goes white.
Again, I expected too much, was told not to, and tried to make this as best I could. With your help I have all the information I need for now.
Big BUT here. This does not look like the camera screen with sliders before. Before, I seem to remember, the sliders were size of the tiny font at the top. Today, they are up bigger, and above the camera button. It is much easier to work with the bigger sliders.
Today, I have taken several pics indoors very near target. Went outside, and fiddled with the settings, and got - images-.
Thank you for your time. I very much appreciate it. It’s not a camera I will use much because of the settings I need to make with each target, indoors, and outdoors being so lighting dependent.
I’ve learned that it’s all a work in progress and not to expect much - I expected too much, thanks to ads. I know better.
[SIDEBAR]
I went into a local store to buy a better cable for phone. And the young clerk saw the phone and recognized it, called it by name “L5” and said how much he’d like to get one. Word is getting around for sure, if the fellow in the store knew about it. This is good.
[/SIDEBAR]
Again, many thanks
~s
