Me too. Have no idea how to fix… Can only say that it appears earlier than phosh upgraded up to 0.45.
Could you check that systemd-resolved is installed?
Can’t even do it. Remember I have to install many apps after the two dist-upgrade? But 1st, it forces me to do a apt install fix broken …, I can install anything at this time. Aftert that command, then it worked and I need to do the 2nd dist-upgrade, after this time, the data is shutoff(both mobile and wifi showed connected, but no data received or sent), I don’t have a chance to install the system-container, resolver, phish, kbd stuff. So it is a deadens.
If your wifi stay connected could you try ti ping some server by IP. e.g. 8.8.8.8? In case if it works just create your own /etc/resolv.conf with the next content:
nameserver 8.8.8.8
Do you have an SD card or a way to get into the filesystem?
Because you can download the necessary files and then install them.
I have had to do that a couple of times
Yeah! In this case @VClaw just could download zip archive or make git clone --depth 1.
Yeah, the phone is working fine just no connection. Terminal works fine. What did you install from the sdcard?
What zip should I download?
You can download the files to an SD from another device and then install them from your phone
So just finish what is left? Install Deb files doesn’t require connection? I can try it.
Thanks, I will try it.
gnome-calls 48~beta.1 is ready for testing!
Just a note, if anyone comes across similar situation. This got solved by deleting first the settings (rm .config/pulse/*), then reinstalling pulseaudio to getting them back (sudo apt-get re-install pulseaudio) and starting the service just for good measure (systemctl --user start pulseaudio). All devices re-appeared. Still don’t know what happened, but I guess it doesn’t matter.
Did you get it figured out?
Negative, something is wrong with the image that I use maybe. I might try again today.
still no working, I am doing the pmos gnome-mobile for now. somehow chatty curosr is in the right position. ha. My other phone is using the backports installed before for coding and testing stuffs, I won’t reinstall that one since too many configurations to make it work. Ha.
You have two L5’s? Why not try doing whole disc image from one and copy it to the other? You can always revert back by overwriting it.
that one i used the pmos and already setuo a lot of stuffs for coding part, so I need to reflash as well. However, too many configurations for my evnironment to setup on Alpine, docker, vscode, gnome builder… took me awhile to make it work, dont want to change it. ha. the one i am using right now, free to flash. just need time ha. tjanks for the advice.
Just how safe is downloading “Byzantium backports unofficial” from Russia’s Yandex dot RU?
We hear so much American anti-Russia propaganda it has me wondering if the file byzantium-backports-240716-2.zip is safe be it is coming from Yandex.
I’m sure @galilley you are confident it is safe. But - ![]()
UPDATE:
I read the following on Yandex wiki
Privacy concerns
[edit]
According to Douglas J. Leith, a computer science professor at Trinity College, Yandex Browser not only sends a hashed hardware identifier to Yandex, but also every letter typed in the address bar and every URL visited by the user.[17]
~s
