I don’t think running the build without installing it is supported. Why won’t you build a deb file with your changes? You can even use the GitLab CI to do that for you.
Master @dos any e.t.a for 10bits main camera sensor driver? HDR…
Multiple reasons. I’m not too much of a fan of these build systems so I always try to keep it as simple as possible and omit whatever I can to lean the process.
In this case millipixels is build after the “ninja” command, hence the only thing I had to do was to figure out where to place the config-file and postprocess-file. Difficult enough, but luckily you could help me out.
I do not know the ninja build system, but the “install” command if I understand correct will overwrite my version of millipixels installed by default? I would really like this not to be the case, then I could end up with a version not being able to take pictures and it would also not be possible to test multiple versions at the same time when the “hanging-bug” occurs.
With the current setup I can compile “my” version of the millipixels in the cloned git folder and I can therefor have two completely distinct versions. I can make adjustments on the go and compile it on the phone. Takes a couple of seconds and I’m ready to test. No need for Gitlab, no deb-files to be installed, and no overwrites of the mainline apps.
Maybe I missing some smart parts of ninja? but it seems that I have all I need so far. ![]()
BTW, one observation I have made is that when the hanging-bug occurred for me last time within the millipixels I’ve compiled, I tried the mainline version and it hang there too. So it seems to be a more “global” problem. But I think that this was already suspected. So maybe no new knowlegde.
You can install into a specified prefix and leave the system-wide version intact.
The hanging problem has been fixed in Millipixels 0.22 released 3 days ago.
Nice, trying it out now.
I’ll try to look at that.
Very nice.
I’ll still be playing around to integrate our trace event iterator, but I don’t expect it to contribute to anything. However it is a cool case to test it out.
I can confirm that I have experienced one case where the old version hang and the new version could take pictures.
@dos said: „The hanging problem has been fixed in Millipixels 0.22 released 3 days ago.“
I‘m on 0.21 and I do not get offered this update with sudo apt update, why?
The release was created on May 9, it has to undergo the usual cycle like every updated packet: Come to landing, migrate to Byzantium main. Takes two weeks or so.
note I have compiled it from source myself
You can download the latest artifact from the Millipixels repo and install the .deb files manually.
Side fact: Note the latest MR draft in the Millipixels repo. It seems flash is beeing worked on.
Correct; I do test it as installed into a prefix, but not in any other way.
Something like this: meson -Dprefix=$HOME/projectbin build ?
Or?
Yes, that’s exactly it.
Not sure if this is covered anywhere, but one very helpful feature to have would be a small(er) and tiny resolutions. This would make sending pics via slow (or expensive) connections and services more quicker and convenient (no hand editing afterwards).
Or such resolution controls within Chats or Geary.
Perhaps you can get multiple resolutions in the postprocess script by using the mogrify command.
Note that iPhone handles this a different way, namely asking you at the time you send whether to scale the image down to a lower resolution copy and send that.
I have tried mogrify on the L5, but unfortunately it is rather processing heavy and, albeit, rather slow in rescaling images.
