Version 4.12-Purism-2 coreboot firmware released for all Librem devices:
Rebased on coreboot 4.12 release tag
Added support for Librem Mini
Adjusted boot display resolution on laptops from 480p to 720p
Addresses full-screen boot display issue on Librem 15v4
Replaced boot logo image with higher quality version
Fixed IOMMU-related issues resulting from change to libgfxinit display init
Fixed issue with internal display failing to init on some devices
Fixed missing ME status print in cbmem log
Updated Intel microcode to latest releases, which address crosstalk-related vulnerabilities:
SKL: D4 → DC
KBL: C6 → D6
Fixed bug preventing use of 6Gbps SATA port speed
applies to all Librem 13v2/3/4, 15v3/4 (Skylake/Kabylake platform)
a small number of drives may still have issues running at 6Gbps,
in which case it is recommended to add ‘libata.force=3.0’ to the
kernel boot parameters to force 3Gbps operation.
I’m working on it and hope to have it released next week. Besides bringing in quite a few improvements and fixes, I need to get the Mini and the laptops on the same page (B12 is the Mini release version, B13 will merge it into the main codebase), which is tricky since they currently require different versions of coreboot.
FYI I’ve just updated my Librem15v4 from 4.11-Purism-1 to to 4.12-Purism-2 using the upgrade utility. Everything went well. The only difference I’ve noticed up to now is that the boot logo is full screen again.
Downloaded and ran PureOS from a thumb drive. It says my hd is there, but not mounted. Not trying to mount, as it has the usual encryption password at bootup
boot normally.
On blue grub screen, press ‘e’ to edit the boot params.
scrolll down the line that starts with ‘linux’ and contains ‘quiet splash’
insert ‘libata.force=3.0’ (without the quotes) after ‘splash’ and before whatever follows that.
press ‘CTRL+x’ to boot with the modified command params
let me know if that helps. I don’t need anything from a live USB or coreinfo.
Not sure what happened, but when I reflashed, it asked if I wanted to reboot. I did so. It appeared to hang. Turned it off, rebooted, errors as above. Booted from USB. Reflashed. Update ok, but would not shut down/reboot. Boot from USB. Mount encrypted drive. Shut down. Hang. Reboot from HD, enter password, all normal.
ok, please understand that when trying to troubleshoot an issue, if you’re going off and doing things that haven’t specifically been asked of you (like reflashing the firmware), it makes it very hard to identify the root cause and determine the proper resolution.
Hit ctrl x, i see the blue grub screen with the debian swirl in the corner. Nothing. Comes back, says it can’t read something, and that I have to boot the kernel first. Then back to the grub edit screen.
Can’t you post pictures of what is happening? I’m not an expert on this but I’m confused with what your are saying here, I don’t know why you are seying Debian logo in grub if you are using PureOS.
I found that the system would sometimes boot correctly, but usually it did not. When I booted from a USB and manually added the encrypted hard drive, it usually worked on the reboot AFTER, but most often it would not boot or provide the password prompt for the hard drive. Sometimes it would say “booting from hard drive” and hang.
I reverted to version 4.11 and it seems to work more reliably. I am relatively inexperienced with Linux, doing most of my changes based on internet solutions found here and elsewhere. Perhaps I made an incorrect series of steps.
